Cascade Crew Message Forums
Spikeophant Member
Joined: 12 Mar 2010 Posts: 164 Location: Bend, Oregon
1986 Chevrolet Camaro IROC-Z
Posted: Fri Mar 19, 2010 8:36 am Post subject: High Flow Cat |
Guys,
I'm getting a few codes thrown from my ecm, A couple for O2 sensor issues, and one for VSS, then one of either egr, alternator, or vats. I'm thinking the O2 sensor is bad, but, I also know my cat is starting to go, she gets pretty stinky if I get on her. Do you have suggestions for high flow cats? I have single inlet dual outlet muffler, so I just need one, and I don't want to start replacing sensors till I replace it.. _________________ 1986 Camaro Z-28 IROC-Z 350 swap |
Spikeophant Member
Posted: Fri Mar 19, 2010 4:50 pm Post subject: |
I decided to just take it in and have the cat put on, I don't really want to lay under it and weld, that's never fun. Got an o2 sensor, and vss, and will stick those in once the cat is in. Should run pretty sweet, cap, rotor, plug, and wires Sunday too. _________________ 1986 Camaro Z-28 IROC-Z 350 swap |
Posted: Fri Mar 19, 2010 5:41 pm Post subject: |
High flow is usually cheaper than stock replacement. Just have the shop weld it in.
You'll find that a lot of aftermarket cats (Magnaflow, ect.) are made by CatCo. It will say in very tiny lettering somewhere on the box. |
