Im buying new valve covers
Mouthwas
PostPosted: Sat Aug 21, 2010 9:15 am    Post subject: Im buying new valve covers Reply with quote
on my 3.1 v6, hard to replace ? cork or rubber? Cork's are 10$ each and rubber is 20$ each, iuno what to do...
But Im not even sure it's the valve covers, but theres oil everywhere around it and below it.. so i think it is...
easy job ? should i remove the intake air manifold and o2 sensor infront would that be easier? thx
PostPosted: Sat Aug 21, 2010 2:39 pm    Post subject: Reply with quote
Rubber.
Don't remove anything preemptively.
O2 sensor is nowhere near the valve covers.
Mouthwas
PostPosted: Sat Aug 21, 2010 2:40 pm    Post subject: Reply with quote
Rubber.
somone said it was inside the air intake ontop of engine
Mouthwas
PostPosted: Sat Aug 21, 2010 2:41 pm    Post subject: Reply with quote
Mouthwas wrote:
Rubber.
witch now he said that i have to remove that to access valve covers
PostPosted: Sat Aug 21, 2010 9:39 pm    Post subject: Reply with quote
o2 sensor is in the exhaust. No need to mess with that. Smile
I second the rubber suggestion.
PostPosted: Sat Aug 21, 2010 9:45 pm    Post subject: Reply with quote
Possibly he was referring to the EGR valve, which is on a tower on the passenger side manifold. Regardless, I stand by what I said before: Don't take anything off until you're sure it's gonna be in your way.
Mouthwas
PostPosted: Sun Aug 22, 2010 2:18 am    Post subject: Reply with quote
Well this looks easy, Lol. I need to go get a ratchet with a deep socket... and just probably need to tighten them up, lol!
there all loose
THis car should run fine and if loosing less oil the oil gauge should be higher correct
PostPosted: Sun Aug 22, 2010 4:16 am    Post subject: Reply with quote
You have a pcv in one of the covers, I would replace it while I'm at it.
The only 2 sensors on the upper intake is the TPS, and IAC(not really a sensor). Neither of them need to be touched, just removed while still bolted to its partner. Whoever is thinking IAT, it is down in the airfilter canister which is no where close. On some of the v8 TPI cars it is in the upper intake
Lower intake will have your ECT, wont need to touch it, just make sure you dont snap it off.
