Posted: Tue Feb 09, 2010 8:57 pm Post subject: It's finally happened |
IT RUNS! Just finished breakin tonight. Started instantly, no overheating, 65psi of oil pressure, no oil leaks, but... I have a soft plug on the back of the passenger head pissing at the firewall. I'll see if I can lever it in further. I even used permatex #1 on it. I guess if all else fails I'll try a rubber plug.
The cam sounds smaller then I expected. It's a summit cam with 282/292 advertised, 224/234 @ 0.050. The stock 2" dual exhaust doesnt sound too bad though. Bit raspy. It'll have to go at some point.. too small.
Last problem.. theres a whole lot more compression then the old motor. Old 400 was a tired 7.9:1... new motor is a fresh 9.8:1.. the stock starter just won't turn her over. Barely does cold. So looks like time for a mini.
Anyway, here's a little vid.
Posted: Tue Feb 09, 2010 9:01 pm Post subject: |
Nice! Another Firebird alive.
Congrats!
Posted: Tue Feb 09, 2010 9:02 pm Post subject: |
sounds great!!!  |
TurdGen1989 Member
Posted: Tue Feb 09, 2010 9:42 pm Post subject: |
sounds beefy! i like it! _________________ Phil.
GMC High Sierra
Posted: Tue Feb 09, 2010 9:49 pm Post subject: |
Might try the Permatex #2 next time. Seems alot stronger than the #1 on that kinda stuff. _________________ A redline a day keeps the carbon away! |
Posted: Tue Feb 09, 2010 9:53 pm Post subject: |
Used #1 because its supposed to harden and hold kind of like locktite. Usually afraid the #2 being pliable would allow the soft plugs to move. You're really not supposed to need anything. The heads had sat quite awhile without the plugs in them though. Bit of rusting had happened. |
Posted: Tue Feb 09, 2010 10:29 pm Post subject: |
That's AWESOME. Can't wait to see it at dyno. _________________
fiveoformula Member
Posted: Wed Feb 10, 2010 1:04 pm Post subject: |
That is awesome! Pontiac actually powered by a Pontiac!  _________________
'88 FORMULA |
Posted: Wed Feb 10, 2010 10:36 pm Post subject: |
That's awesome, the dual 2" exhaust sounds pretty good on my system. _________________ 92 Camaro
Posted: Wed Feb 10, 2010 10:54 pm Post subject: |
| Al Hasse wrote: | | That's awesome, the dual 2" exhaust sounds pretty good on my system. |
True, but he has 30% more displacement than you, Al.  |
Posted: Wed Feb 10, 2010 11:00 pm Post subject: |
| aaron_sK wrote: | | Al Hasse wrote: | | That's awesome, the dual 2" exhaust sounds pretty good on my system. |
189ci to 400ci....... More like 111% :OP
3.1 - 6.5 _________________ A redline a day keeps the carbon away! |
Posted: Wed Feb 10, 2010 11:05 pm Post subject: |
| Isnt Al talking bout his stereo system though? LOL |
Posted: Wed Feb 10, 2010 11:09 pm Post subject: |
I am, PC audio system anyway A good subwoofer can make almost any exhaust recording sound good. |
Posted: Wed Feb 10, 2010 11:21 pm Post subject: |
| Most of the sound problem is with the chincy mic's they incorporate into cameras. The recording sounded closest to real when I was walking along side the car, from the rear it was clipping. |
Posted: Wed Feb 10, 2010 11:27 pm Post subject: |
| chevymad wrote: | | Isnt Al talking bout his stereo system though? LOL |
Posted: Wed Feb 10, 2010 11:40 pm Post subject: |
Obviously Paul and I are far to interested in the math. |
Posted: Thu Feb 11, 2010 7:09 am Post subject: |
| aaron_sK wrote: | | chevymad wrote: | | Isnt Al talking bout his stereo system though? LOL |
We should get into Db next!  _________________ A redline a day keeps the carbon away! |
Posted: Thu Feb 11, 2010 7:50 pm Post subject: |
Well I was able to lever that soft plug in a bit further and the leak seems to be sealed! Not a drop so far.. but i'm betting i'll be the one to wet down steve's dyno and piss him off. Needless to say some stopleak will be going in.
Also there's a huge exhaust leak somewhere.. sounds almost like muffler.. sounds awful anyway. That exhaust will have to go soon. The motor itself seems to have quieted down a whole lot, which is good. Got it all dialed in tonight. Tomorrow I'll drop the breakin oil and install new battery cables and a mini starter. Hopefully that will cure the hotstart blues.
Need to get this on the road pronto. Get some shakedown runs in. I know I've still got some electrical gremlins in the dashboard to chase too. |
fiveoformula Member
Posted: Fri Feb 12, 2010 12:05 pm Post subject: |
| What do you have in mind for the exhaust?? |
