Leejo2005 Member
Posted: Thu Feb 18, 2010 8:45 pm Post subject: Balancer question |
| When using a double roller timing set, is the use of a different harmonic balancer required? Mine goes on smooth but stops about 1/4 inch too short so the pulleys wouldn't line up. |
Posted: Thu Feb 18, 2010 8:50 pm Post subject: |
| It uses the same balancer. It's possible you're hangin up on the keyway. Make sure hte woodruff key is in all the way and level. |
