Posted: Thu Feb 18, 2010 7:36 pm Post subject: Dyno curse, who's it got??? |
Who's it got this year? Even though I haven't decided to put my car on the rollers, or even which car to bring, my 89 sort of broke down this morning.
While waiting for our driver at the Park-n-Ride where we meet, I noticed some liquid meandering from under the car, but was still too dark to see where it was coming from. My first guess was water pump. On the way home, I let it get up to temperature, then pulled off into a service station and opened the hood to find water slinging off the water pump pulley. I suppose the shaft seal is shot.
I've always wondered when it might go. It looks to be original as does the timing cover, even after 200,000 miles Looks like part of a long vacation weekend will be spent under the car  _________________ 92 Camaro
Posted: Thu Feb 18, 2010 7:45 pm Post subject: |
Well as of right now the Camaro has oil pressure AND runs through the gears without a hitch from the motor.
Mazda seems to be working well with the new header/modified intake.
We shall see. I think money will be my curse. _________________ A redline a day keeps the carbon away! |
Posted: Thu Feb 18, 2010 8:13 pm Post subject: |
I hear Paul on the money thing. Barring anything drastic I think i'm good to go. But I've got alot of small things to fix, and you know how that is.. all it takes is time and money!
No leaks or anything under the car tonight. Still holding good oil pressure and running cool... fingers are crossed! |
Posted: Thu Feb 18, 2010 9:27 pm Post subject: |
I have nothing wrong so far but I'm crossing my fingers, knocking on wood and praying.  _________________
d00012 Member
Posted: Thu Feb 18, 2010 11:06 pm Post subject: |
No job soon enough...firebird is grounded.
I probably will make it in my Camaro, but doubt I will run it on the dyno. |
popballz Member
Posted: Fri Feb 19, 2010 1:05 am Post subject: |
My red car was totaled and the alternator just blew in my blue car....
Does either one of those count?? _________________ -Donald
Posted: Fri Feb 19, 2010 1:49 pm Post subject: |
| New pump is in. Waiting now for the RTV to set up on the gaskets. There was nothing left of the seal on the old one the way it sounded when I spun the shaft. |
Posted: Fri Feb 19, 2010 4:01 pm Post subject: |
| Al Hasse wrote: | | RTV to set up on the gaskets. |
Posted: Fri Feb 19, 2010 6:11 pm Post subject: |
| Twilightoptics wrote: | | Al Hasse wrote: | | RTV to set up on the gaskets. |
Hehe.. more goo is good isnt it??  |
Posted: Fri Feb 19, 2010 7:56 pm Post subject: |
| chevymad wrote: | | Twilightoptics wrote: | | Al Hasse wrote: | | RTV to set up on the gaskets. |
I didn't use a whole lot of it. Maybe a little more than necessary to hold the gaskets in place while installing the pump. I used that black stuff in the cheese whiz can, applying the most at the outside edge of the gasket and around the bolt holes |
Posted: Fri Feb 19, 2010 8:02 pm Post subject: |
Myself, I usually glue the gasket to the pump, then use a thin layer between the gasket and the engine. That way when I go to remove it the gasket stays with the old pump and its easier for me to clean.
90% of the gaskets on an engine should be either just glued on, or put on dry. The only normal places for the stuff in a tube is the china walls, and anywhere where 2 gaskets meet. Or if something is pitted really bad. I think Paul's shock smiley is because as a mechanic we see lots of do it yourselfers using tons of goo where they shouldnt be using any.
Mostly we're giving you a hard time.  |
Posted: Fri Feb 19, 2010 8:07 pm Post subject: |
| chevymad wrote: | Mostly we're giving you a hard time.  |
I kinda had that figured out already  |
Posted: Fri Feb 19, 2010 8:10 pm Post subject: |
| chevymad wrote: | | as a mechanic we see lots of do it yourselfers using tons of goo where they shouldnt be using any. |
Pffft. If a thin layer is good, then a thick layer is great, right? ...Right? _________________
Posted: Fri Feb 19, 2010 8:12 pm Post subject: |
| popballz wrote: | My red car was totaled and the alternator just blew in my blue car....
Does either one of those count?? |
Donald, does that mean you're coming to Dyno with the blue car?! |
popballz Member
Posted: Wed Feb 24, 2010 2:42 pm Post subject: |
| iansane wrote: | | popballz wrote: | My red car was totaled and the alternator just blew in my blue car....
yep! with a squeaky new alternator!
(it randomly squeaks really really loud ) _________________ -Donald
Posted: Wed Feb 24, 2010 5:24 pm Post subject: |
Return it!
Then tell them you changed your mind and you wanted a 12si instead.  |
Richster Magic Fingers
Posted: Wed Feb 24, 2010 8:19 pm Post subject: |
Well throw me into the loop!
I am having the upholstery done in the Shark, started great, then POW the fabric I choose was almost a week late coming in, the leather showed as scheduled.
Then the dude doing the work has been out with the flu
When it comes to interior...NO RUSHING IT!  _________________
Posted: Wed Feb 24, 2010 8:34 pm Post subject: |
| Lawnchair. Zip ties. Problem solved. |
Posted: Wed Feb 24, 2010 10:09 pm Post subject: |
| aaron_sK wrote: | | Lawnchair. Zip ties. Problem solved. |
Posted: Thu Feb 25, 2010 8:47 am Post subject: |
I had a nightmare about dyno curse last night. It was horrible. Everything kept going wrong.
Been daily driving the Camaro for a week or two to flush out any bugs before the big weekend, and it's been running flawlessly so far... *knock on wood* _________________ 84 Camaro Z28 - LS1/T56
