Posted: Sun Jan 10, 2010 10:50 am Post subject: geek squad question |
have some computer files that are 4+ gig. Every time I attempt to move them to a different drive, it says that drive is full. Yet I have 100,276, whatever gig free (plenty for the file).
Is there a "wall" in xp's system that wont allow me to do this? _________________ 2008 GMC Z71
85 T/A WS6 Member
1985 Pontiac Trans Am
Posted: Sun Jan 10, 2010 11:23 am Post subject: |
I see that in Vista, on the command line,
netsh int tcp set global autotuninglevel=disabled
will fix lag time with large files, not sure about XP
Try copy, then delete instead of move? _________________
Leejo2005 Member
Posted: Sun Jan 10, 2010 11:27 am Post subject: |
| Quote: | | I have 100,276, whatever gig free |
Roughly 98 TB that's a huugely massive hard drive, whenever they end up making them. |
Posted: Sun Jan 10, 2010 11:38 am Post subject: |
| Some hard drive file systems won't accept files that large. What file system is the drive you're trying to move it to formatted in? |
Outlaw28 Member
Posted: Sun Jan 10, 2010 1:39 pm Post subject: |
| i move large files all the time on xp...i moved 30gbs of files from one hard drive to another....you could try zipping them up to make them smaller |
Posted: Sun Jan 10, 2010 3:47 pm Post subject: |
My PC has a 320gig hd, partitioned out to 3 sizes.
I have tried moving it across the 3 diff partitions, wont go.
I am wanting to moving it to an external drive that is 1tb, that has 276gig of space left. Wont go.
I tried another external 1tb that has 100gig left. No go.
I have not tried copy, then delete. |
Posted: Sun Jan 10, 2010 3:50 pm Post subject: |
just tried copy. No go  |
Posted: Sun Jan 10, 2010 3:52 pm Post subject: |
netsch is not recognized as an internal or external command, operable program or batch file. |
Posted: Mon Jan 11, 2010 5:10 am Post subject: |
eh, thats likely the problem then. And I have no space to transfer this stuff off, and reformat the thing.
Live n learn!! |
Posted: Mon Jan 11, 2010 3:26 pm Post subject: |
file struture is it.
I have another drive, 320gig USB1 NTFS
Its transfering over to it.... taking 2hrs for a 5.6gig file  |
Posted: Mon Jan 11, 2010 4:44 pm Post subject: |
ok, that drive was bad. But it was given to me.
Installed a different drive into that case, were on a roll now, lol. |
