Tranny concerns
kutison
PostPosted: Sat Jan 02, 2010 3:11 pm    Post subject: Tranny concerns Reply with quote
New problems have arisen since my fiddling with the ignition switch, P/N switch, starter relay, and VATS.
When I shift to drive, from park. it works fine. but after a short drive to refill my tires, the tranny doesn't want to shift into park. Confused
is this something I caused?
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger
townaj
PostPosted: Sat Jan 02, 2010 6:53 pm    Post subject: Reply with quote
When my car started doin that I had to adjust the shifter cable where it connects to the transmission. Idk if thats what yours is but its worth a try.
kurfbird
PostPosted: Sat Jan 02, 2010 7:27 pm    Post subject: Trans Reply with quote
The bolts loose up on the tans cable bracket that bolts on the trans.
Out friend almost messed up my 92 becasue the bolts came loose.
Jack it up and see if they have come loose.
kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com
kutison
PostPosted: Sun Jan 03, 2010 1:48 pm    Post subject: Reply with quote
good guesses but it looks like the connector running between the P/N switch and the Shift lever is out of place. Does anyone have a picture of the P/N switch in the proper position?
How do I remove the center console so I can get to the P/N switch, just taking the cover off gives me clearance issues between the P/N switch screws and the inside wall of the center console.
kurfbird
PostPosted: Sun Jan 03, 2010 2:27 pm    Post subject: Pm me your email Reply with quote
OPm me your email and I will take some pics of the switch.
The bolts for the console are inside the box on the bottom 10 mm . there is also one that bolts to the floor 10 mm under the a shift plate. Only was to get cleerance is to remove console. aslo there is two 7 mm bolts on the dash center. something there there some times there not.
kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
kutison
PostPosted: Mon Jan 04, 2010 10:01 am    Post subject: Reply with quote
Alright, I was making a big deal out of nothing (as usual) I was able to loosen the P/N switch and using a flathead, push the actuator between the switch and shifter back into it's fitting. took 5 minutes, no big deal.
