Not giving up..
ChrisB
PostPosted: Mon Jan 04, 2010 6:25 pm    Post subject: Not giving up.. Reply with quote
So I've been trying to sell the Trans Am as is not running, but it's hard to sell a non running car as you can imagine. So I decided to give it another shot and see if I can't get it running hopefully. I noticed the fuel pump wasn't priming so I started on that path. I jumped 12v to the g port on the fuel pump port on the ALCL and the pump did come on. It primed and when I tried to start it, it did actually come to life for a brief moment. It was the first sign of life I've seen out of it in about a month, so I got a little optimistic. I went and picked up a fuel pump relay and replaced it. Still not working..The pump's still not priming with the new relay, but it will if I bypass the relay.
Any ideas why this is? I wish I had more than an hour of daylight after I get home from work. Thanks.
91 Z28
PostPosted: Mon Jan 04, 2010 6:31 pm    Post subject: Reply with quote
Wires can get pulled out out of the relay plug pretty easily. (Ask me how i know this Razz) Check that all of them are in good shape at the plug.
