Tampered or Factory?
Boostd1
PostPosted: Wed Dec 23, 2009 9:14 pm    Post subject: Tampered or Factory? Reply with quote
I just can't tell. My buddy picked this up for his WS6 not long ago. Its a .57 Trim Garrett (Similar to that of a 3071R)
On the exhaust side of the turbo, it appears the shaft has been grinded down a bit. I assume this is for balancing. Is this something Garrett does? Is this something the previous owner did? Turbo is brand new, never spooled/mounted.
2008 Saturn Astra XR | Sold
PostPosted: Thu Dec 24, 2009 12:22 am    Post subject: Reply with quote
That's gotta be from the factory for balancing. I doubt many people have the skills or equipment to balance something at 80,000 rpms. Laughing
Boostd1
PostPosted: Thu Dec 24, 2009 1:08 am    Post subject: Reply with quote
That's what I'm trying to get at. I cant tell if someone just F'd with it for the hell of it, or if its balanced by Garrett themselves.
PostPosted: Thu Dec 24, 2009 7:51 am    Post subject: Reply with quote
Contact Garrett.
I've only seen a dozen or so up close, but even my turbo doesn't have any grinding. It's an Air-Research.
PostPosted: Thu Dec 24, 2009 9:15 am    Post subject: Reply with quote
Contact Garrett.
The AR/Garrett I picked up for Steves scoobaru years ago had the shaft ground on, figured it was normal for balancing...
Boostd1
PostPosted: Thu Dec 24, 2009 3:20 pm    Post subject: Reply with quote
That's what I'm thinkin'. A few Garrett guys on Club GP says it's normal as well. Just thought I'd see if you guys knew.
