Smoked out!
PostPosted: Mon Oct 26, 2009 5:45 pm    Post subject: Smoked out! Reply with quote
Hey all,
So i finally decided to follow Al's recommendations and bought a can of nightshades and smoked out my tail lights and front markers. Stuff was a pain to use but eventually got it figured out. here are the results.
PostPosted: Mon Oct 26, 2009 5:52 pm    Post subject: Reply with quote
Looks good Thumbs up
PostPosted: Mon Oct 26, 2009 6:20 pm    Post subject: Reply with quote
Cool Looking good bud.
PostPosted: Mon Oct 26, 2009 7:29 pm    Post subject: Reply with quote
Looks awesome!
PostPosted: Mon Oct 26, 2009 7:52 pm    Post subject: Reply with quote
Smoke or get clear amber side markers!
Otherwise looks good!
PostPosted: Mon Oct 26, 2009 9:39 pm    Post subject: Reply with quote
sweet man looks good
PostPosted: Tue Oct 27, 2009 5:54 am    Post subject: Reply with quote
thanks guys,
The sides are already smoked out Smile Now i just need the windows tinted and a grille!
PostPosted: Tue Oct 27, 2009 6:21 am    Post subject: Reply with quote
83Z28BlackBetty wrote:
thanks guys,
Ahh. Your sig picture is so huge I thought it was part of your display!
PostPosted: Tue Oct 27, 2009 10:43 am    Post subject: Reply with quote
Yo Jake...looks great man!
The Black Betty Scheme is looking to be in completion... now the tint for a final touch
and it is a good thing down your way...how are things working out for you, I hope all is well!
Drop a line man...I am around!
jakemk8706
PostPosted: Wed Oct 28, 2009 8:28 am    Post subject: Reply with quote
what made it hard to use? i have had the blacked out lenses before, but was thinking going this route. but im a bit worried i might ruin perfectly good set of tail lights.
gas brake dip dip
PostPosted: Wed Oct 28, 2009 9:16 am    Post subject: Reply with quote
For me, the stuff likes to crack in the drying process. A trick I learned when building plastic models works really well. Clean the lenses extremely well, then get your can of paint warm (hot water works well), and if you can, get the lens surface up to temperature also, I used a space heater. I also found a plastic adhesion promoter, which is a clear primer that seemed to help (found it at NAPA).
jakemk8706
PostPosted: Wed Oct 28, 2009 5:09 pm    Post subject: Reply with quote
would it crack during the drying process?
gas brake dip dip
PostPosted: Wed Oct 28, 2009 5:50 pm    Post subject: Reply with quote
It was all in the prep work. That's why it cracked (like spiderweb) on me the first time or two. Get the lenses really clean before spraying them.
PostPosted: Wed Oct 28, 2009 8:57 pm    Post subject: Reply with quote
yeah that was it. I focused on painting very thin coats. if i made more than to short passes, it would crack while drying. after that i used some buffing and polishing compound on em to shine them up Smile i'll get some pics when its sunny down here soon.
PostPosted: Wed Oct 28, 2009 11:32 pm    Post subject: Reply with quote
those single line tail lights look ten times better when they're smoked or blacked out. Looking really good. I never had a problem with the tiny spiderweb cracking when did mine, I took my time, thoroughly cleaned the lenses and made many very light coats.
