A warning about fords.
PostPosted: Sat Sep 19, 2009 11:41 am    Post subject: A warning about fords. Reply with quote
Very Happy Actually this is more of a warning about being safe and using parts that are up to the task you put them to. Also a good show of why you should run a scattershield for racing.
http://www.network54.com/Forum/74182/thread/1252775447/So+you+think+you%27ve+had+a+bad+day-+Must+see
PostPosted: Sat Sep 19, 2009 1:57 pm    Post subject: Reply with quote
Wow yeah. I'd like to see the flywheel itself.
Tore the block apart too!
I like my legs.
PostPosted: Sat Sep 19, 2009 2:00 pm    Post subject: Reply with quote
Part of the flywheel is in the pile of pieces. Ring gear looks pretty stretched!
PostPosted: Sat Sep 19, 2009 2:54 pm    Post subject: Reply with quote
Hooly shat. Shocked
Looks like whatever was left of the flywheel smashed through a paint cabinet. Lucky there weren't any thinner cans busted open, or that could have gotten even worse.
dlp
1990 Chevrolet Camaro IROC-Z
PostPosted: Sat Sep 19, 2009 6:31 pm    Post subject: Reply with quote
Wow. Just goes to show that flywheels and harmonic balancers need to be purchased for high output engines. I was on a safety safari crew (no training) at Sacramento Raceway in the late 80's and had to pick up a toe from a guy that lost his flywheel.
Spend the money when in question on the things that keep you save...
PostPosted: Sat Sep 19, 2009 7:48 pm    Post subject: Reply with quote
Shocked
Guess I'd better hurry up and put my scattershield in.
