HONDASLAYER Member
Posted: Wed Sep 02, 2009 4:31 pm Post subject: Not a Camaro issue but a very big one for me.......... |
ok my explorer won't start. it will turn over it will sputter but it will not fully start and run. the most it will do is sputter for a few sec. then die out. i have 15gallons of gas. It drove fine on the way to the court house after work. I parked it and returned after about 40 min. It started but as soon as i put it into gear it started sputtering then died.
.. I don't know what it is. I'm hopping it's not the fuel pump That would suck major. I think it's the inertia switch, but i wasn't in any collision. or it could be the filter. I'm hopeing it's the filter. thats cheap..... _________________
Posted: Wed Sep 02, 2009 5:02 pm Post subject: |
Filters don't go tits up like that. It's a progressive clog.
Fuel pumps do. Need to put a gauge on it.
Look for obvious vacuum lines, etc. _________________ A redline a day keeps the carbon away! |
HONDASLAYER Member
Posted: Wed Sep 02, 2009 7:53 pm Post subject: |
| Twilightoptics wrote: | Filters don't go tits up like that. It's a progressive clog.
Look for obvious vacuum lines, etc. |
i depressed the spader valve while it was cranking and there was no pressure in the line. so we're pretty sure it's the pump. now i just got to figure out how i'm going to drop the tank and change the pump on an explorer with a 22gal. tank with as much clearence as the maro. _________________
Posted: Wed Sep 02, 2009 10:14 pm Post subject: |
Before yanking the pump make sure you have power back there. _________________
Leejo2005 Member
Posted: Wed Sep 02, 2009 10:46 pm Post subject: |
| You mentioned the inertia switch. I assume you already tried that? Mine was located in the trunk on the driver's side of the latch on my mustang. |
TA350 New Member
Joined: 29 Aug 2009 Posts: 16 Location: Melbourne, Australia
1985 Pontiac Firebird
Posted: Thu Sep 03, 2009 2:33 am Post subject: |
I had the same symptoms on my ford falcon.
The misses ran the tank down to almost empty the day before and it picked up a heap of crap from the bottom of the fuel tank.
i eventually got it started and drove it like i stole it on the FWY. _________________ "Its not the speed that kills, Its the sudden stop". |
Posted: Thu Sep 03, 2009 7:02 am Post subject: |
If there is no fuel pressure it shouldn't sputter and cough. It just won't start at all.
If the pump isn't running, could be pump, wiring (fuse) or inertia switch.
Paul's right. Fuel filters usually don't just clog instantly.
Make sure inertia switch is reset, test power at the pump with a multimeter. Go from there.
Good luck. _________________ 84 Camaro Z28 - LS1/T56
HONDASLAYER Member
Posted: Fri Sep 04, 2009 12:37 pm Post subject: |
Ok i got a fuel pump from all american classics here in vancouver for $40. Now i just gotta get 3 5gal. fuel tanks a floor jack and 2 jackstands and i'm ready to do this thing.
on a side note all american classics have like 20+ thirdgen Camaro's and firebirds. they have rebuilt t-5's for $600 and everything else that you will find on our cars. They pull the part while you wait. and it's usally only a few bucks more than LKQ. They are online and can ship their parts nation wide. here's that address... http://www.allamericanclassics.com . _________________
Posted: Fri Sep 04, 2009 2:48 pm Post subject: |
| HONDASLAYER wrote: | Ok i got a fuel pump from all american classics here in vancouver for $40. Now i just gotta get 3 5gal. fuel tanks a floor jack and 2 jackstands and i'm ready to do this thing.
on a side note all american classics have like 20+ thirdgen Camaro's and firebirds. they have rebuilt t-5's for $600 and everything else that you will find on our cars. They pull the part while you wait. and it's usally only a few bucks more than LKQ. They are online and can ship their parts nation wide. here's that address... http://www.allamericanclassics.com . |
All american is a rip off. I forget you're new to the area. Most of us here know this and stay away. Even my shop tries everywhere else before them, even if we know they have something we need.
They are ridiculously proud of what they have. I'd be very very suprised if the "rebuilt" T5 was indeed rebuilt.
If you find a thirdgen in an LKQ you'll pay 1/3 of what All American wants. They even wanted $100 for a stock v6 thirdgen seat that was moldy!
On an exploder note.... used fuel pump is bad ju-ju. _________________ A redline a day keeps the carbon away! |
Posted: Sat Sep 05, 2009 10:11 am Post subject: |
All-American Classics is cool, but they overvalue everything. I went there once but never again.
What's LKQ?
Good luck with that used fuel pump.  _________________ 84 Camaro Z28 - LS1/T56
HONDASLAYER Member
Posted: Sat Sep 05, 2009 1:16 pm Post subject: |
I gave the fuel pump some juice and it worked fine. I'm not doing this as a perminent fix. just going to have it in there until i can afford a new one. with everything else going on right now i'm spread way thin.
So i got my jack and jack stands today and after waiting in the rain for an hour cause i locked my keys in the car i'm finally home. But oops, i forget to get 3 5gal. gas cans  _________________
Posted: Sat Sep 05, 2009 9:22 pm Post subject: |
So the pump works?! or no?
LKQ is who bought U-Pull-it
78th st vancouver, damascus on sunnyside, foster rd just off foster.
ETC ETC _________________ A redline a day keeps the carbon away! |
HONDASLAYER Member
Posted: Sat Sep 05, 2009 10:18 pm Post subject: |
| Twilightoptics wrote: | | So the pump works?! or no? |
ya it works. I'm doing the job tomorrow. I jacked it up today but i only had 1 2ton and 1 2.5ton the 2ton one doesn't go up as high as the 2.5 so i'm going feness it up a little bit more tomorrow. _________________
HONDASLAYER Member
Posted: Sun Sep 06, 2009 9:10 pm Post subject: |
well it's done. The new pump works freakin great. And it only took 5 hrs. and one trip to the parts store....Oh and one 12pack. The bauer is runnin better than before. BOOYAH BABY.......  _________________
