have a quick question
Saber
PostPosted: Thu Sep 03, 2009 9:49 am    Post subject: have a quick question Reply with quote
my dad was telling me fords fuel filters are direction well my moms x boyfriend changed my fuel filter and let just say he isn't the best person to work on my car (tweeker) are Camaros fuel filters directional if they are directional would it give me a lose of fuel pressure
View user's profile Send private message Send e-mail Yahoo Messenger
PostPosted: Thu Sep 03, 2009 10:10 am    Post subject: Reply with quote
It could.
Get under there and look for the arrow.
Do you have a gauge on there to verify you're losing pressure?
jakemk8706
PostPosted: Thu Sep 03, 2009 10:37 am    Post subject: Reply with quote
i just put on it a few months ago and im pretty sure it had an arrow on it, and the arrow points towards the motor.
gas brake dip dip
Saber
PostPosted: Thu Sep 03, 2009 11:44 am    Post subject: Reply with quote
i had my car in the shop and them told me im pushing 25 pounds of pressure and its supposed to be 44 to 45
PostPosted: Thu Sep 03, 2009 2:52 pm    Post subject: Reply with quote
Is your RS a TPI car or TBI?
If it's TBI you should be around 12psi and there is no pressure port.
If it's TPI you should be around 40-43 engine running vacuum off regulator. There is a pressure port.
Saber
PostPosted: Thu Sep 03, 2009 3:00 pm    Post subject: Reply with quote
my car is a v6 multi port injection and that's just what the guy told me at the shop
PostPosted: Thu Sep 03, 2009 5:10 pm    Post subject: Reply with quote
I'd throw another one on it just to be sure. Even if it isn't backwards, it could still just be clogged.
kurfbird
PostPosted: Thu Sep 03, 2009 8:04 pm    Post subject: MPFI v6 Usually run about 38-43 PSI Reply with quote
25 pSI is way to low. Put another filter on there just to be sure. But could be your pump is on its way out
kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com
Saber
PostPosted: Thu Sep 03, 2009 8:12 pm    Post subject: Reply with quote
yeah im just going to change out the pump and filter sunday anybody up to helping hondaslayer and me
