Headswap
PostPosted: Thu Aug 20, 2009 10:08 am    Post subject: Headswap Reply with quote
ok, heads should have arrive today, so over next month I gotta start collecting gaskets/etc.
Vette spark plugs
Head Gaskets
Intake gaskets
Exhaust gaskets
TPIS?? runner gaskets
Antifreeze
Headbolts
Injectors n orings
Am I missing anything else?
May have found a vette base intake. And a MAP plenium Burnout
PostPosted: Thu Aug 20, 2009 7:48 pm    Post subject: Reply with quote
Throttle body gasket (should be able to buy an entire TPI top-end kit)
CopperCoat
Ultra Black
Icehouse Razz
Run LT1 injectors if you can. Work better than the stock L98's IMHO.
Get RemFlex gaskets for the exhaust if you're running headers. Those things rock.
Oh and no antifreeze in new heads/intake until you know they are not leakers.
PostPosted: Fri Aug 21, 2009 4:31 am    Post subject: Reply with quote
Half that stuff you listed I dont even know what it is?
Coppercoat. Heard of it, but whats it for?
Ultra Black?
where do I get remflex gaskets?
PostPosted: Fri Aug 21, 2009 8:18 am    Post subject: Reply with quote
I'm with stupid I have them on my 89, havn't had to retorque the header bolts yet...
You can find a dealer from their home page.
http://www.remflex.com/
PostPosted: Fri Aug 21, 2009 9:18 am    Post subject: Reply with quote
Ultra Black?
CopperCoat is some cool tacky spray stuff you use on shim-style headgaskets. I use it on the composite ones too, but technically I don't think you're supposed to.
Ultra Black is Permatex oil-proof RTV. Use it instead of the cork end gaskets when you install the intake manifold. Also put a thin bead of it around the water jacket ports on the intake gasket itself.
PostPosted: Fri Aug 21, 2009 9:59 am    Post subject: Reply with quote
ahh, Ive only done 2 head jobs and never used copper coat. When I get gaskets, I'll post them and let me know if its a must with them.
Ultra Black, If I get a whole top end gasket set, I "think" it comes with this. If not, Ive got some left over from my v6 days.
PostPosted: Fri Aug 21, 2009 10:27 am    Post subject: Reply with quote
I tend to toss the "included" RTV from those sets in the same place I put the cork end gaskets. Wink
PostPosted: Fri Aug 21, 2009 12:00 pm    Post subject: Reply with quote
Laughing
PostPosted: Fri Aug 21, 2009 1:16 pm    Post subject: Reply with quote
Don't use the copper coat on the composite ones. It's meant for the shim style.
I'd definitely use the 1094 felpro shim gaskets. Since your engine wont be zero decked if it's factory. The composite gaskets are way thicker increasing cubic inches a hair, but also increasing pinging potential. And Definitely use the Copper on the shim.
Don't use the rubbers the intake kit gives you for the china wall, use "THE RIGHT STUFF" It's fantastic silicone stuff. Run a 1/4" bead from gasket to gasket.
If you clean the heads and intake well enough you don't need ANY goo around the waterjackets. It just makes it 10 times more PITA to clean the next time it comes off.
IMHO you don't need to change injectors.
PostPosted: Sun Aug 23, 2009 4:39 am    Post subject: Reply with quote
I have to change injectors, I have a bad one. Or atleast get a set I have cleaned.
