Chevelle
'92 camaro boss
PostPosted: Sat Aug 15, 2009 11:09 pm    Post subject: Chevelle Reply with quote
i bought a 68 chevelle, it's just the shell
i have a 350 motor that's out of a 76 sierra i'm going to put in as a temp so i can drive it around, but idk what to put in transmission wise, and it has a 10 bolt rear end, but no gears..
you guy's being the pros you are i seek knowledge on what to put in
can you help
'92 camaro boss
PostPosted: Fri Aug 21, 2009 12:44 pm    Post subject: Reply with quote
Alright..no help?
a buddy say's he'll sell me a turbo 400 trans, but i know nothing about rear axle gears..
if anyone's mad about previous posts my bad..just stated my oppinion.
PostPosted: Fri Aug 21, 2009 3:47 pm    Post subject: Reply with quote
Well since I don't remember your last post, or if I was supposed to be mad at you, I'll throw my two cents in. Laughing
Is it a drag project? Cruiser? More info on usage would help.
If the 400 is a working 2wd tranny, I would go with that.
Gears are 100% personal choice, but remember that compromise sucks. I run 3.50's behind my C6 with (IIRC) 29" tires, and it's a touch high off the line, and way too low on the freeway.
'92 camaro boss
PostPosted: Sat Aug 22, 2009 8:30 am    Post subject: Reply with quote
just want a cruiser mostly..later down the road i'm going to either rebuild, or buy a new motor with a little more get up and go.
PostPosted: Sat Aug 22, 2009 9:35 am    Post subject: Reply with quote
That might be a 10 bolt rear end, but it's larger than the ones in our F-bodies. We have a 7.5/7.625 inch rear, and doing some research, that era Chevelle has an 8.2 inch rear. You should be able to find some nice gears for it. I have a set of 3.73 gears almost ready to install into my 89 and maybe wake it up a bit Cool
PostPosted: Sat Aug 22, 2009 9:39 am    Post subject: Reply with quote
If you're going cheap, just throw the 400 in, find a complete 10-bolt on CL, and drive it.
PostPosted: Sat Aug 22, 2009 2:16 pm    Post subject: Reply with quote
I'm with stupid
Get whatever you can get ahold of to make it drivable, it might be less work if you find a whole complete rearend thats ready to go in, just something to think about..
But just get it to run and drive then eventually you'll want some more power. Very Happy
'88 FORMULA
