Posted: Wed Aug 05, 2009 1:45 am Post subject: Drum to Disc Swap |
Drums suck. Mine hardly do anything in terms of braking performance and recently my RR Brake cylinder started leaking. I also need to do a brake tune up anyway. I know it would be a quick, cheap and easy fix, but the thought of fixing drum brakes just seems like a bit of an oxymoron to me.
So the question is: What all is entailed in swapping a drum setup from an '85 10 bolt to a disc setup; either 1LE, PBR or standard iron? _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Wed Aug 05, 2009 7:17 am Post subject: |
There is an FAQ on TGO that explains it. Really easy to do but you'll have to get the rotors, calipers, abutment brackets, and maybe a thin spacer. Worth it though, I upgraded to LT1 rears. Biggest pain was the ebrake cable stuff but I think I did it the hard way. _________________ E30
Posted: Wed Aug 05, 2009 10:01 am Post subject: |
I just flat replaced the whole rear axle on mine, so I think I went the "easy way". I had problems finding the correct cables because they got damaged in removal.
My ebrake still doesnt work for crap. Dunno whats up with it. _________________ 2008 GMC Z71
Posted: Wed Aug 05, 2009 10:50 am Post subject: |
i swapped mine to a posi 9 bolt with discs.
Posted: Wed Aug 05, 2009 11:51 am Post subject: |
Easier to just swap to a rearend that has what you want. I personally have a '99 Camaro SS posi disc rear in my car. _________________ 84 Camaro Z28 - LS1/T56
Posted: Wed Aug 05, 2009 2:11 pm Post subject: |
I still got my 3.73 Disc rear.
I'm open to reasonable offers. It's seriously just sitting on an old piece of carpet in the basement. _________________
Posted: Wed Aug 05, 2009 2:20 pm Post subject: |
| How soon are you looking to swap? If chris' axle doesn't work out, I'll be pulling the disc backing plates off my axle here in the next few months to finally upgrade the rear brakes as well. |
Posted: Thu Aug 06, 2009 2:50 pm Post subject: |
I am looking to do this immediately. Brake fluid starts getting expensive after going through a few bottles. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Sat Aug 08, 2009 3:01 am Post subject: |
Chris, what condition is it in? It's a posi, disc, 3.73 rear? If so how much and when can we meet? _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
