so any suggestions on what or where to go
Outlaw28
PostPosted: Fri Aug 07, 2009 4:34 pm    Post subject: so any suggestions on what or where to go Reply with quote
so anyone know of a good paint/body shop thats got fair prices and good quality work in the kitsap area...i might consider paying to have it fixed if i find a decent shop but im tight on my budget right now so i was considering doing it myself although i have no experience in it...ive been sanding my new bumper cover and pass side quarter panel gfx down...
basically the passenger side quarter needs to be replaced but i cant afford it so im trying to fix it up best as i can...also my front chin spoiler needs to be redone again...from scraping...
dlp
1990 Chevrolet Camaro IROC-Z
PostPosted: Fri Aug 07, 2009 6:39 pm    Post subject: Reply with quote
That will require alot of work, and wont come cheap if you just drop off the car at a shop. You will be surprised at how much money you can save by doing the grunt work. Pull the carpet, passengers seat, sail panel, headliner, rocker panel, and anything that would be in the way of removing the rear quarter and or installing a new / used rear quarter. Then take it in and ask what it would cost. Tell them you are not in a hurry, but would like to have it done in 1 month. Then tell them you will do all of the color sanding and buffing but you want 3 coats of clear applied.
Most large shops wont bite, but the little guys that have been around for a while will do it for cheap. Just have to make it easy for them.
