Posted: Fri Jul 17, 2009 11:35 am Post subject: |
I'd take one... if it could turn more than 102RPM! _________________ A redline a day keeps the carbon away! |
Posted: Fri Jul 17, 2009 11:55 am Post subject: |
Ive seen the assy pics before, but never a true completed pic, or the specs on it.
Slightly bigger then whats used on a locomotive  |
Posted: Fri Jul 17, 2009 3:25 pm Post subject: |
What do they use to start that? _________________
Posted: Fri Jul 17, 2009 5:13 pm Post subject: |
| In the first pic it appears to have a starter on the far side of the flywheel. |
dlp Member
1990 Chevrolet Camaro IROC-Z
Posted: Fri Jul 17, 2009 5:19 pm Post subject: |
| Wonder what a Flowmaster would sound like on that monster. |
HONDASLAYER Member
Posted: Fri Jul 17, 2009 7:41 pm Post subject: |
Man can you imagine having to replace a cam on one of those???  _________________
Posted: Fri Jul 17, 2009 7:56 pm Post subject: |
Cat makes a 15.8 liter truck engine that makes something like 1850 ft lbs of torque. That giant engine there makes twice the ft lbs of torque per liter. That is impressive.  |
Posted: Sat Jul 18, 2009 7:18 am Post subject: |
| aaron_sK wrote: | | In the first pic it appears to have a starter on the far side of the flywheel. |
For some reason I think that starter has more torque than my car. |
Posted: Sat Jul 18, 2009 4:40 pm Post subject: |
| iansane wrote: | | What do they use to start that? |
Apparently so. Some smaller shipboard diesel generators are started with high pressure air. I think they get them spinning before they introduce the fuel - but I may be wrong  |
Posted: Sat Jul 18, 2009 4:56 pm Post subject: |
| iansane wrote: | | aaron_sK wrote: | | In the first pic it appears to have a starter on the far side of the flywheel. |
And instant torque...  |
Posted: Sat Jul 18, 2009 5:54 pm Post subject: |
| I wonder if the starter is a large diesel. Some old cat engines were started with a gasoline pup engine. You started the gas engine, then engaged the clutch to the diesel engine. You then got it spinning with a compression release like Al said. Once its spinning good you closed the compression release and the diesel took off on its own. |
