carburetor's and cornering
PostPosted: Wed Jul 08, 2009 2:09 pm    Post subject: carburetor's and cornering Reply with quote
Can anyone give me a pointer on getting a carburetor to take hard corners well? Last time I took my car out on a corner it bogged a bit and acted like it had no power. I assume that I had a jet uncover but is there anythinge else to look for? I have side float bowls on a mechanical secondary 4150 DP with a single PV setup.
PostPosted: Wed Jul 08, 2009 2:44 pm    Post subject: Reply with quote
Get rid of the side hung float bowls and you're golden. Laughing
Make sure your float level is set properly, and make sure you have more than 1/4 tank of gas!
PostPosted: Sun Jul 12, 2009 9:50 am    Post subject: Reply with quote
I'm with stupid Thumbs up
PostPosted: Sun Jul 12, 2009 6:34 pm    Post subject: Reply with quote
don't worry Travis. With a big-block, you won't be able to go around corners anyway. Razz Wiggly wiggly
PostPosted: Mon Jul 13, 2009 7:07 am    Post subject: Reply with quote
Not with traction anyway.....
