91camaro_rs Member
Posted: Fri Jul 17, 2009 11:49 am Post subject: brake question |
| My friend has a 92 camaro, he had his brakes done awhile ago and the pads are fine, pretty sure the rotors are too, but when he brakes the car pulls to the right. could this mean the brakes just need to be bled? |
kurfbird Member
Posted: Fri Jul 17, 2009 11:54 am Post subject: Brakes |
I would replaced the rubber brake hoses. Made a big difference when I installed new rubber brakes hoses. Brakes straight. Have done it to all my thirdgens. _________________ kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com |
Posted: Fri Jul 17, 2009 12:01 pm Post subject: |
More than likely the flex line to the LEFT side has failed. Have them both replaced because the other isn't far behind. _________________ 92 Camaro
Posted: Fri Jul 17, 2009 12:05 pm Post subject: |
Calipers could be bad too. _________________ A redline a day keeps the carbon away! |
Posted: Fri Jul 17, 2009 3:15 pm Post subject: |
Whoever replaced the brakes, did they just do a pad slap? (new pads, maybe turned rotors and left everything else?) _________________
izcain 9sec Club
Posted: Fri Jul 17, 2009 7:19 pm Post subject: |
If you are going to install new brake lines look for like a set of stainless braided lines. It will really add to the braking feel! _________________
9.17 @ 148 |
