Juice for old-school T-5
PostPosted: Fri Jun 26, 2009 8:44 am    Post subject: Juice for old-school T-5 Reply with quote
Old (83) non-WC T-5: does it need ATF, or 70wt gear oil? Book says gear oil, interwebs say just about everything under the sun.
I was thinking Royal Purple 70wt, but I figured I'd ask the experts first.
d00012
PostPosted: Fri Jun 26, 2009 9:51 am    Post subject: Reply with quote
This book says 80w/90 GL lubricant. I think 70wt should be fine.
I know 85+ uses ATF.
PostPosted: Fri Jun 26, 2009 10:33 am    Post subject: Reply with quote
WC-T5 = ATF
PostPosted: Fri Jun 26, 2009 10:51 am    Post subject: Reply with quote
blue89 wrote:
WC-T5 = ATF
ATF is used in the mid 80's.
PostPosted: Fri Jun 26, 2009 7:54 pm    Post subject: Reply with quote
aaron, I have a Non-WC T-5 in mine, and I run a 50/50 mix of 80W gear oil and ATF. Still haven't broken mine yet, and I ain't exactly nice to my trans.
Rod also said he runs gear oil in his non WC.
Just something to note. Lots of diff opinions about what's the right stuff on the internet.
PostPosted: Fri Jun 26, 2009 8:10 pm    Post subject: Reply with quote
nope, it just won't shift into 2nd, Razz
No idea what the 83's run, I have a WC, and run ATF.
PostPosted: Fri Jun 26, 2009 8:12 pm    Post subject: Reply with quote
Sure it does. you just have to ignore that grinding sound Wink
PostPosted: Fri Jun 26, 2009 8:20 pm    Post subject: Reply with quote
you do what? Would you put ATF in your differential or gear oil in your crankcase? No beuno!!!!
PostPosted: Fri Jun 26, 2009 8:25 pm    Post subject: Reply with quote
are you suggesting I ought to run a straight amount of either ATF or gear oil and not mix the two?
PostPosted: Fri Jun 26, 2009 8:28 pm    Post subject: Reply with quote
I think he is suggesting that you run the lube that the tranny was designed to use. Pretty neat concept, eh.
PostPosted: Fri Jun 26, 2009 8:31 pm    Post subject: Reply with quote
therein lies the problem john. Heard both Gear oil and ATF are proper for non WC T-5's.
I've read both are correct, and the jury seems to be out about what's the proper one.
so I "tony-ed" it and ran both.
PostPosted: Fri Jun 26, 2009 8:40 pm    Post subject: Reply with quote
It should say on the tranny. Mine has a label on, saying that it needs Dexron-III.
PostPosted: Fri Jun 26, 2009 8:49 pm    Post subject: Reply with quote
no label on mine. Also yours is a 1990 trans. Hense, its a WC. I know for a fact mine's a non WC, and I removed it from an 85 z/28.
PostPosted: Fri Jun 26, 2009 9:02 pm    Post subject: Reply with quote
I have heard of doing that before. I ran straight gear oil in my T5 for a few years then changed it out for synthetic ATF plus a bottle of Lucas trans additive. It really doesn't matter which oil you run much. I think the gear oil is better, but it robs horsepower. When cold my car would roll forward in neutral when I would let the clutch out. Also made it hard shifting when cold and took longer for the engine to idle. Another option would be to run a straight 30w engine oil.
Also Barts old 83 TA had ATF in it when I pulled that 5 spd.
PostPosted: Fri Jun 26, 2009 9:09 pm    Post subject: Reply with quote
The only internal differences of interest between a w/c and non are the first and second gear synchros and the countershaft has tapered bearings rather than barrell bearings. Both have a small plastic pump on the end of the counter shaft. All t5 in my humble limited professional opinion should use ATF. It's not a sloppy trans like old four speeds. There are tapered bearings on both t5 main shafts that require end play and have much tighter tolerances.
PostPosted: Fri Jun 26, 2009 9:15 pm    Post subject: Reply with quote
But heavier oil isn't going to hurt anything.
PostPosted: Fri Jun 26, 2009 9:53 pm    Post subject: Reply with quote
They changed to ATF to lube those tighter tolerances and run through the passages better. Also the ATF seems to allow the synchros to work better.
PostPosted: Sat Jun 27, 2009 12:19 am    Post subject: Reply with quote
Wow, you guys are about as decisive as the rest of the forum posts I've been reading on this.
Either way I will probably run ATF. It's cheap, I slam shifts a little bit (well alot) so easier shifting is better, and Paul said so, so I can blame him if it F's up. Laughing Laughing
mrpopo573
PostPosted: Sat Jun 27, 2009 1:38 pm    Post subject: Reply with quote
My tranny calls for ATF and half the contour guys run gear oil instead. I chose Amsoil ATF and it changed everything for the better.
305302eater wrote:
2000 Maxima SE 5 Speed VQ30
PostPosted: Tue Jun 30, 2009 12:05 pm    Post subject: Reply with quote
I first ran gear oil in my Non-WC T-5, cause that's what came out of it when I rebuilt it. It shifted really hard and seemed to rob too much power.
I dumped the gear oil out and put ATF in it, and it's been fine for about 30,000 hard shifting miles.
Run ATF. It won't break nothin' and it'll shift way better. Laughing
