Tranny Question
bejitto101
New Member
PostPosted: Sat Jun 20, 2009 9:31 pm    Post subject: Tranny Question Reply with quote
This is an easy question I would assume. Would a automatic tranny from 1994 Chevy Camaro 3.4l v6 work in my 1989 Firebird 2.8l v6?
View user's profile Send private message AIM Address Yahoo Messenger
PostPosted: Sat Jun 20, 2009 10:02 pm    Post subject: Reply with quote
Since the 3.4L is pretty much a drop in replacement for both the 2.8L and the 3.1L, the tranny should work too.
PostPosted: Sat Jun 20, 2009 11:27 pm    Post subject: Reply with quote
Depends on how the trans is controlled. I know in some vans in '93 the line pressures were already being controlled by the ECM.
If the trans has 4 wires and is a 700R4 then you might try it. If it's got more than 4 wires, then definitely no.
PostPosted: Sun Jun 21, 2009 9:01 am    Post subject: Reply with quote
Thanks Paul, I forgot something may be up with the ECM.
91camaro_rs
PostPosted: Sun Jun 21, 2009 2:06 pm    Post subject: Reply with quote
i thought the 4th gens used the 4L60e?
PostPosted: Tue Jun 23, 2009 6:15 am    Post subject: Reply with quote
I believe the 93-95's got a 4L60 (700R4).
PostPosted: Tue Jun 23, 2009 6:30 am    Post subject: Reply with quote
Still a different trans. It's based on a 700 though.
bejitto101
New Member
PostPosted: Tue Jun 23, 2009 7:53 pm    Post subject: Reply with quote
So basically when I go to the junk yard to take a look, if it has more than 4 wires, its a no go? I'm looking into one that Kitsap Truck and Auto in Port Orchard has because its the closest tranny for my car. Closest auto tranny out of a third gen is in Kent. Unless someone here has one they're willing to sell.
I'm also planning on getting a 3.4l v6 out of a 94 bird, but that's out in Shelton.
PostPosted: Wed Jun 24, 2009 6:23 am    Post subject: Reply with quote
The 4l60e has a round plug on the passenger side with something around 20 pins in a square fashion.
bejitto101
New Member
PostPosted: Wed Jun 24, 2009 8:21 pm    Post subject: Reply with quote
So the 4L60e is a no go but the 700r4 will work? Sorry, when it cars I'm a noob, just trying to learn so I can fix my bird up.
PostPosted: Thu Jun 25, 2009 6:27 am    Post subject: Reply with quote
Correct.
