cameron7710 Member
Posted: Wed Jun 10, 2009 6:00 pm Post subject: awsome news |
well i got a call from one of my friends today and turns out his neighbor has a jeep that he need to get rid of and said i could have it for free
i talked to the guy and he said that its in great shape and everything the only problem is there is a small crack in the block in a water jacket so it leaks all the water out in 5-10 min but the engine itself runs great. so im gona go pick it up on Saturday and decide what to do with it. one thing tho since the crack isnt in the cylinder walls or anything would it be at all possible to take it to a shop and have them weld the crack up? _________________
Posted: Wed Jun 10, 2009 6:07 pm Post subject: |
| It all depends on where the crack is. Normally welding isnt the best way to fix one in a cast block though. Some people have ok luck, some dont. You could also "stitch" the crack if its accessible. You buy a type of plug, then drill, tap, insert plug.. then do the same thing over. Overlapping each plug. If its not accessible you could always try the "waterglass"/block seal method. Sometimes that works. |
cameron7710 Member
Posted: Wed Jun 10, 2009 6:24 pm Post subject: |
cool ill take a look at it when i get it.wont hurt to try everything other wises im gona use it to see how hard it would be to rip out a motor  _________________
Posted: Wed Jun 10, 2009 8:05 pm Post subject: |
if it's a 4.0L you picked a hell of a motor to try ripping out first!
A crack that big usually means more problems. You're probably best to get a running motor off craigslist and drop it in. _________________ A redline a day keeps the carbon away! |
cameron7710 Member
Posted: Wed Jun 10, 2009 9:28 pm Post subject: |
| Twilightoptics wrote: | if it's a 4.0L you picked a hell of a motor to try ripping out first!
A crack that big usually means more problems. You're probably best to get a running motor off craigslist and drop it in. | hmm that sucks now i just hope its not a 4.0L(with my luck it probly is) but ya i already got my eye on craigslist (even tho i cant afford anything or even know for sure what kind of engine im looking for:lol:) _________________
GREG DAVIDSON Member
Posted: Fri Jun 12, 2009 7:01 pm Post subject: |
| bout %90 of the jeeps have the 4.0 in them we've had no problems with the one my mom had and now coreys buying off her |
cameron7710 Member
Posted: Fri Jun 12, 2009 7:57 pm Post subject: |
| GREG DAVIDSON wrote: | | bout %90 of the jeeps have the 4.0 in them we've had no problems with the one my mom had and now coreys buying off her | ya it probly is o well ill just have to find out for sure tomarrow _________________
corey davidson Member
1986 Chevrolet Camaro
Posted: Fri Jun 12, 2009 9:21 pm Post subject: |
if all else fails an du cant do any thing with i need a parts jeep mainly rims and tires and id buy it off u but if i were u check it out and if its the 4.0l high output go to any junk yard and should find the parts u need exspet down here were im to slow to get them for both of my cars _________________ real men are covered in oil and grease |
Posted: Fri Jun 12, 2009 9:50 pm Post subject: |
| corey davidson wrote: | if all else fails an du cant do any thing with i need a parts jeep mainly rims and tires and id buy it off u but if i were u check it out and if its the 4.0l high output go to any junk yard and should find the parts u need exspet down here were im to slow to get them for both of my cars |
That's got to be a new f*ckin' record right there.  |
Posted: Fri Jun 12, 2009 10:57 pm Post subject: |
| rjmcgee wrote: | | corey davidson wrote: | if all else fails an du cant do any thing with i need a parts jeep mainly rims and tires and id buy it off u but if i were u check it out and if its the 4.0l high output go to any junk yard and should find the parts u need exspet down here were im to slow to get them for both of my cars |
Couldn't have said it better myself. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
cameron7710 Member
Posted: Fri Jun 12, 2009 11:16 pm Post subject: |
will see i need to get it and figure out what to do i still might just sell it for parts but idno. but if i do i was told the tires have a good 35-40 thousand miles left on um _________________
Posted: Sat Jun 13, 2009 1:19 am Post subject: |
f*ck i no i cant spell or write good you have to finish school to do that boys! so iv been told that my G.E.D. isnt schooling so f*ck! But ok yea keep me up dated and if u need any help if u do keep it i might be able to help _________________ real men are covered in oil and grease |
cameron7710 Member
Posted: Sat Jun 13, 2009 9:29 am Post subject: |
ok will do, well i was just about to leave to pick it up and i get a call that he cant do it to day cause he need to find the title and get some tax things takin care of with it. so its lookin like i have to wait till around wendsday  _________________
Posted: Sat Jun 13, 2009 11:02 am Post subject: |
| cameron7710 wrote: | | hmm that sucks now i just hope its not a 4.0L(with my luck it probly is) |
4.0L is the best engine ever put in a Jeep. Hope it is a 4.0L straight six. |
Posted: Sat Jun 13, 2009 12:59 pm Post subject: |
| QwkTrip wrote: | | cameron7710 wrote: | | hmm that sucks now i just hope its not a 4.0L(with my luck it probly is) |
Posted: Sat Jun 13, 2009 5:58 pm Post subject: |
| 4.0 is where it is at. Love mine. |
Posted: Sat Jun 13, 2009 6:00 pm Post subject: |
| QwkTrip wrote: | | 4.0L is the best engine ever put in a Jeep. Hope it is a 4.0L straight six. |
I'd venture to say the LSx is the best engine ever put in a heep.  |
Posted: Sat Jun 13, 2009 6:01 pm Post subject: |
| iansane wrote: | | QwkTrip wrote: | | 4.0L is the best engine ever put in a Jeep. Hope it is a 4.0L straight six. |
I dunno, the Cummins diesel swaps are pretty bad arse. |
Posted: Sat Jun 13, 2009 6:35 pm Post subject: |
| Dewey316 wrote: | | iansane wrote: | | QwkTrip wrote: | | 4.0L is the best engine ever put in a Jeep. Hope it is a 4.0L straight six. |
But then you get stuck with a Heep and a rattle crap engine.  |
Posted: Sun Jun 14, 2009 9:18 am Post subject: |
I can't say I've seen that. Like a 4bt or something? |
