91camaro_rs Member
Posted: Sun Jun 07, 2009 6:48 pm Post subject: b-day coming up |
| so my b-day is coming up and i been wondering, with the b-day $$$ what would be a good upgrade for the camaro? anyone got any ideas? |
flea Member
Posted: Sun Jun 07, 2009 7:47 pm Post subject: |
guess it depends on how much you will get. my mother in law wouldn't bankroll an air freshener.
91camaro_rs Member
Posted: Sun Jun 07, 2009 10:20 pm Post subject: |
| probly around $100 to $300 somewhere in there |
Posted: Sun Jun 07, 2009 10:53 pm Post subject: |
If it was me I'd start with the steering issue first. Getting that fixed is gonna be cheaper than a new pair of front tires.
Other than that, are you sticking with the 6, or moving to an 8? |
Posted: Mon Jun 08, 2009 6:30 am Post subject: |
Fix the steering then go to suspension. _________________ A redline a day keeps the carbon away! |
91camaro_rs Member
Posted: Mon Jun 08, 2009 10:14 am Post subject: |
| yeah steering will be fixed before my b-day comes around i get paid this week, and as suspension goes i have new struts/shocks and my springs are new too...they just arent lowering springs... and im kinda in a pickle between v6 and v8, only reason i dont wanna go v8 is cause i just spent 1700 on a new tranny, and i know i wont get that much back if i sell the v6 w/tranny. so ill probably stick with V6 but not 100% sure |
Posted: Mon Jun 08, 2009 3:25 pm Post subject: |
So continue to build the platform.
Subframe connectors.
Strut Tower Brace.
Poly bushings.
Torque arm.
Sway bars, bushings, endlinks.
etc. _________________ A redline a day keeps the carbon away! |
redlava Member
Posted: Mon Jun 08, 2009 5:21 pm Post subject: |
| I would defiantly look into some sub-frame connectors |
91camaro_rs Member
Posted: Tue Jun 09, 2009 11:44 am Post subject: |
| ok cool, looks like ill be going for poly bushings and subframe connectors, and end links, would it be cheaper/easier to just get sway bars from an Iroc or Z28? |
91camaro_rs Member
Posted: Tue Jun 09, 2009 11:57 am Post subject: |
| ok i was on summit lookin at stuff, and all the strut tower braces are for TPI none for V6 does it really matter if it says for TPI cars only? and for the subframe connectors the summit catalog says like $110 for them and the website says $265 |
Posted: Tue Jun 09, 2009 2:43 pm Post subject: |
Get weld in SFCs. Like Spohn's. They bolt in the control arm, and then get welded to the pinch weld. and gusseted to the subframe. _________________ A redline a day keeps the carbon away! |
redlava Member
Posted: Tue Jun 09, 2009 4:51 pm Post subject: |
| yeah don't get the ones from jegs or summit get umi, spohn or bmr that can be welded in. I definatly watch the junk yards for the sway bars or classifieds on TGO you can typically get the 36/24 mm sway bar combo for 60 dollars. |
91camaro_rs Member
Posted: Tue Jun 09, 2009 5:10 pm Post subject: |
| sweet ill probably get some after all my steering parts are put in.... |
