91camaro_rs Member
Posted: Sun May 31, 2009 10:28 pm Post subject: gear change |
| im upgrading rear ends, i will have a 4.10 gear ration so what new speedo gear do i need for my tranny? |
Posted: Mon Jun 01, 2009 6:24 am Post subject: |
What tire size and what drive gear is in what transmission? _________________ A redline a day keeps the carbon away! |
91camaro_rs Member
Posted: Mon Jun 01, 2009 11:55 am Post subject: |
| my tires are 245/45/17 and my rear end is 3.23 now, and i have no idea what gear is in the tranny, all i know is that it is a olive green color, and its the stock one. |
91camaro_rs Member
Posted: Mon Jun 01, 2009 12:48 pm Post subject: |
| blue89 wrote: | http://www.miata.net/garage/tirecalc.html
25.7" tire
http://www.transmissioncenter.net/speedometer_calibration_______va.htm
If your speedo is correct, then you should have an 18/45
When you put the new rear gears in, a 15/45 will get you close but you'll still read about 6% faster. That's the trouble with 4.10's in our cars with stock sized tires. The Transmission Center sells the stuff you need to get it changed over. |
well my tires arent completly stock size but pretty close...that website said it will say 53mph if i am going 50 and thats for a 26 inch tire...so i guess i need the 15/45 then. |
Posted: Mon Jun 01, 2009 2:50 pm Post subject: |
What transmission is this?
It's a 26" tall tire according to TCI.
I don't understand how you guys are figuring this.
Are you saying your speed driven gear has 45 teeth and you're only changing the drive gear?! _________________ A redline a day keeps the carbon away! |
91camaro_rs Member
Posted: Mon Jun 01, 2009 9:51 pm Post subject: |
| well i wouldnt worry about it anymore, i was supposed to pick up the rear end tomorrow but he just told me he sold the whole car...dang it |
