Boostd1 12sec Club
Joined: 28 Oct 2008 Posts: 437 Location: Thornton, Colorado
Posted: Thu May 14, 2009 12:29 pm Post subject: 4T65e = Garbage! |
So I fried my tranny yesterday at the track...
So I did my burnout, got the tires nice and sticky. Cut a good light, pulled a 1.9 sixty foot but it felt like the tranny was slipping. Got into second pullin' pretty good. at the 1000 foot, it would not shift into third and I had to let up a bit and it went into forth.
I got my slip, 13.6 @ 102 which sucked because I uped my boost and was expecting better
On the way to the pits I noticed the revs dropped when I put it into first gear. The car now revs in first gear freely and will not grab unless the car is moving and even then it still revs. 1-2 shift seems okay, 2-3 does not exist, I have to let up the throttle to 0% TPS for it to go into fourth and it drives and the motor doesn't rev.
All in all, my tranny is pretty fried. I guess putting 16 PSI boost through a stock tranny isn't a good idea! _________________ 1998 Grand Prix GT | 12.91 @ 103 - Sold/Retired
2008 Saturn Astra XR | Sold
2007 Infiniti G35x | Current DD |
Posted: Thu May 14, 2009 5:27 pm Post subject: |
The trans in the GTP's are the weakest link.
From the last time I was on CGP, the intense trannys were fairly crappy. Dunno if they have redone them, or someone better has come along. _________________ 2008 GMC Z71
Posted: Thu May 14, 2009 6:28 pm Post subject: |
| Will a 4T80E from the caddy or Aurora swap in? |
Boostd1 12sec Club
Posted: Thu May 14, 2009 8:24 pm Post subject: |
| 91RSVert wrote: | The trans in the GTP's are the weakest link.
From the last time I was on CGP, the intense trannys were fairly crappy. Dunno if they have redone them, or someone better has come along. |
ZZPerformance has one that will hold up to almost 850 wheel horsepower so I think I'll be good there. But I'm going with a TripleEdgePerformance tranny...the guy specializes in 4T65E's especially. _________________ 1998 Grand Prix GT | 12.91 @ 103 - Sold/Retired
Posted: Thu May 14, 2009 10:00 pm Post subject: |
I don't know anything about fwd trans but can you swap in the 6speed from the g6?  _________________
Posted: Fri May 15, 2009 5:47 am Post subject: |
| Last time i looked, someone was infact working on a 5sp or sp swap from a fwd car. I forget the details. Surely they have it completed by now. |
Boostd1 12sec Club
Posted: Fri May 15, 2009 7:33 am Post subject: |
| iansane wrote: | I don't know anything about fwd trans but can you swap in the 6speed from the g6?  |
It has been successfully installed once _________________ 1998 Grand Prix GT | 12.91 @ 103 - Sold/Retired
Posted: Fri May 15, 2009 5:47 pm Post subject: |
| Boostd1 wrote: | | iansane wrote: | I don't know anything about fwd trans but can you swap in the 6speed from the g6?  |
It has been successfully installed once |
Well there's your trans. Everything is better with a 6speed.
I thought I remember seeing v8 archie put one behind an ls7 so they might be able to handle some power, right? |
Boostd1 12sec Club
Posted: Fri May 15, 2009 7:12 pm Post subject: |
| iansane wrote: | | Boostd1 wrote: | | iansane wrote: | I don't know anything about fwd trans but can you swap in the 6speed from the g6?  |
He matched up a G6 6 speed to an LS7???  _________________ 1998 Grand Prix GT | 12.91 @ 103 - Sold/Retired
