Joined: 19 Nov 2005 Posts: 3229 Location: Bremerton, WA
Posted: Sat May 02, 2009 4:34 pm Post subject: LS1 rear upgrade started....Finished!! |
I figured since I had the rear end apart to replace an axle shaft, I may as well start the bigger brake upgrade to the rear. I already have about 95% of the stuff I need to do this, I only lack some brake lines and fittings which I can't really figure out until I get the brakes on the car.
This is the cast iron caliper setup on the driver side.
Caliper and axle shaft removed, leaving the backing plate, and the backing plate removed..
In progression, new backing plate with parking brake shoe, new rotor, caliper bracket, caliper and pads and a test fit with the wheel.
 _________________ 92 Camaro
Joined: 23 May 2006 Posts: 2792 Location: Bellingham/Eugene
Posted: Sat May 02, 2009 5:05 pm Post subject: |
Yup, just one piece. You can see the adjusting wheel at the bottom of the backing plate, pretty nice setup.
I also found out that the backing plate only fits one way, must be true for the old ones too. I somehow got one turned 90* when placing it against the axle flange (thought I had the e-brake adjuster to the bottom), then the bolts wouldn't line up Looked at it one more time and thought "how did I get it turned like that?" - Funny how things go together when they're lined up correctly  |
izcain 10sec Club
Joined: 09 Sep 2006 Posts: 874 Location: Port Angeles WA
Posted: Sat May 02, 2009 9:53 pm Post subject: |
oh yea! lookin good Al!  _________________
1983 Z28 Too much to list. New Best 10.48 @ 127.68 MPH on a hyd. flat tappet cam |
Joined: 08 Jan 2004 Posts: 6192 Location: Bringing the tech
Posted: Sat May 02, 2009 9:54 pm Post subject: |
| Looks good! |
bAd DaWg 85 Z28 Member
Joined: 14 Jan 2004 Posts: 132 Location: Taking up space
Posted: Sun May 03, 2009 12:24 am Post subject: |
ya been there done that gee hope no one saw that hehe looks good man. _________________ If ya can't fixit F#ck IT!!!!!!.........
DaWg
85 Z28
65 Chevy sport truck
85 K20 4x4 truck |
Joined: 24 Oct 2005 Posts: 3270 Location: Silverton/Salem/Portland
Posted: Sun May 03, 2009 7:58 am Post subject: |
looks good so far al!
Keep us posted on the progress. _________________
alloy T56 Elitist
Joined: 25 Jan 2004 Posts: 1534 Location: Vancouver, WA
Posted: Sun May 03, 2009 8:42 am Post subject: |
One thing I forgot to mention Al was that I removed the ABS sensors and used a small 7/8" plastic push in plugs I got at Lowes. I think the cost was $.75 each. They come on black and white as I recall. I figured since I would never use the sensors why not remove them and plug the holes up. _________________ Member of the "Elite T56 Club" , big brake club, soon to be a 9" club member, and "burgundy" (not red or maroon) car owner.
Posted: Sun May 03, 2009 8:57 am Post subject: |
Would that be where the depression is to the rear of the backing plate? If so, then mine didn't come with the sensors in them.
I'm making a parts list for my brake lines now as I want to redo the whole axle line (hard line is pretty inexpensive and easy to form). I might take your list to Belfair Hose on a day off to assemble something for me, maybe the axle T-fitting also. |
alloy T56 Elitist
Posted: Sun May 03, 2009 9:26 am Post subject: |
Just show them this pic and they should easily be able to make the hoses up for you. I think the hose itself was only 4" long, but don't hold me to that measurement. Measure for yourself.
Here is a pic of the backing plate. The hole is the one on the right. A 7/8" plug fits nicely, and the axle flange slightly overlaps the plug when you bolt the backing plate on so there is no chance of it falling out.
If I go out and about today I'll try and find one of the plugs and take a pic of it for you.
Posted: Sun May 03, 2009 9:45 am Post subject: |
The stock hose is only 5" plus the crimps. The 90* fitting in your setup could very well use the same length hose as that would relieve alot of strain.
My backing plates didn't come ready for the ABS sensors as the hole isn't punched out. I was wondering what that depression was for when I was cleaning and painting them up. |
alloy T56 Elitist
Posted: Sun May 03, 2009 10:15 am Post subject: |
Believe me 4" of hose is plenty of strain relief. The 4th gen rear is about 2" wider per side, and the LCA lower mount where the brake hose attaches is in the exact same location as a 3rd gen axle, so you are 2" less distance the hose has to reach using the 4th gen brakes on a narrower 3rd gen axle housing. The distance is so short that's why I used a 90 deg. fitting so the hose won't be in a bad bend. Mount the stock hose up and you will see what I mean. And you can easily use the stock hose to get a length measurement.
I actually could have went an even shorter hose and it would have worked perfectly, but I made the hoses up myself and even the 4" hose was difficult to make using the reusable style fittings. There just isn’t much hose to grab on to when making them up. _________________ Member of the "Elite T56 Club" , big brake club, soon to be a 9" club member, and "burgundy" (not red or maroon) car owner.
Posted: Sun May 03, 2009 10:21 am Post subject: |
| Where did you get your hose and fittings from? Did you have to do any crimping? from your picture, it almost looks like a compression type fitting on the hose. |
alloy T56 Elitist
Posted: Sun May 03, 2009 10:53 am Post subject: |
I got my parts from Oil Filter Service in Portland. And they aren't crimped, they are reusable fittings and use a small ferrule. The size is -3. You push the barrel onto the hose first, then you have to push the small ferrule into the hose end and make sure it's seated completely. Then you insert the male hose fitting into the hose and slide the barrel up and tighten it down. I made this sound easy, but getting that little ferrule to seat can be a pain. After the first one or two you will be a pro at making them.
To cut the line wrap the hose with electrical or duct tape, and clamp in a vise and use at least a 32 tooth hacksaw blade to cut it with. You need a clean cut so the ends aren't unraveled. _________________ Member of the "Elite T56 Club" , big brake club, soon to be a 9" club member, and "burgundy" (not red or maroon) car owner.
Joined: 13 Jan 2004 Posts: 6767 Location: Seattle, WA
Posted: Sun May 03, 2009 11:22 am Post subject: |
You can always just use AN lines. That's what I did for my rear brakes. Banjo to AN line. Ran premade AN lines the length I needed to AN fittings adapted to the hardline. _________________ A redline a day keeps the carbon away!
www.huskytrucks.com/seattle.php
"Just remember: There are two things in life where penetration is important... and welding is one of them. -Aaron" |
Posted: Sun May 03, 2009 6:38 pm Post subject: |
I'm almost as far as I can go now without making the new flex lines. I'm trying my hand at making new hard lines on the axle with the stuff NAPA has. I got two 6' pieces with the correct fittings on them, just need to cut to bend and cut to length and flare the cut end. The stuff is cheap enough so that if I mess up, it's easy enough to get a new piece. I need a day off during the week to make a trip to Belfair Hose & Supply so I can have them make up those flex lines, including the T-block - that would be easiest for me.
In the mean time, I'll see about the e-brake cables and brackets - time to drop the drive line and torque arm to make room to work. Hey Dan, how did you remove the e-brake cable bracket from your car to make room for the 4th gen bracket? |
alloy T56 Elitist
Posted: Sun May 03, 2009 8:53 pm Post subject: |
Here is a pic of how someone else did it on TGO. They cut the front of the 4th gen braket off and used it with the third gen front bracket. I wanted to have the cables spaced the correct distance from the front cable, so I just cut off the front bracket behind the bend with my die grinder and mounted the complete 4th gen bracket. Works perfectly.
Posted: Sun May 03, 2009 9:01 pm Post subject: |
| So you just cut the tabs (for lack of a better term) from the bracket and left the body of it in place? I gather you left the guides for the rear cables in place too. |
alloy T56 Elitist
Posted: Sun May 03, 2009 9:12 pm Post subject: |
You got it. That's exactly what I did. _________________ Member of the "Elite T56 Club" , big brake club, soon to be a 9" club member, and "burgundy" (not red or maroon) car owner.
Posted: Sun May 03, 2009 9:46 pm Post subject: |
| Thanks, now to see if my angle grinder will fit up there - might have to remove the guard. |
