poncho 350
PostPosted: Fri May 01, 2009 6:22 pm    Post subject: poncho 350 Reply with quote
anyone have any clue how hard it would be to put one of these in a bird ??
http://salem.craigslist.org/pts/1150063714.html
PostPosted: Fri May 01, 2009 7:06 pm    Post subject: Reply with quote
Too much trouble for a 350. If you were going 400 or larger could be worth it. You'd need a pontiac transmission or bellhousing, fabricate mounts, all the poncho accessories etc. There's a pretty decent thread on tgo about doing it. They fit pretty well when done. Originally pontiac had planned to put the 301 in the 82 transam, but gm nixed the idea and decided to use the "corporate v/8"
PostPosted: Fri May 01, 2009 8:36 pm    Post subject: Reply with quote
Kiss your stick goodbye unless you go Hydraulic Throw Out and re-plumb.
