28 spline 10 bolt axles
PostPosted: Wed May 06, 2009 8:59 am    Post subject: 28 spline 10 bolt axles Reply with quote
I'm trying to upgrade. I have a spare 10 bolt drum housing, a 28 spline auburn limited slip, and 3.42's. Only problem is that I don't have the axles! Can anyone help me out? The first drift event is May 17th and I'm trying to make it there AND drive it down there. My current axle is too high for highway use so I need to swap them. Either that or try to put this thing on a trailer. Any leads would be great, I'd drive as far as seattle for a decent set of 28 spline 10 bolt axles.
PostPosted: Fri May 08, 2009 8:33 am    Post subject: Reply with quote
Nothing? I'll take the whole rear end if someone has one.
PostPosted: Fri May 08, 2009 1:07 pm    Post subject: Reply with quote
When I did this a few years ago I could't find any used. Moser wasn't all that expensive, that's the route I finally went.
Red Bird
1991 Pontiac Firebird
PostPosted: Sat May 09, 2009 7:20 pm    Post subject: Reply with quote
id hit up the boneyards try to find a 90+ v6 or v8 car or good ol craigslist
1991 Firebird L03 T-5
