| Black Scoop |
| Yes |
66% |
[ 8 ] |
| No |
33% |
[ 4 ] |
| Total Votes : 12 |
Posted: Fri May 01, 2009 9:51 am Post subject: Talk me down man..... |
So to catch you up, carburetor, intake, cold air, hood clearance.
My engine is too big to fit a standard circle air filter on the carb AND have it clear a stock hood. As it is, the gutted hood I have is sitting on the stud that screws a filter down. To run a filter, I'd have to get a hood scoop of some sort. I'm really doubting that I'll have to get a turbo. This engine is that beef cake now. So hood scoops are expensive. Not to mention there is no way to attach a fiberglass scoop to a metal hood and blend it with filler. It will always crack or look like i bolted a scoop on the car. Yuck. I could get a fiberglass hood with a built in cowl but those are $400-700. I can think of lots of go fast parts for that much. So as it is:
$90 to 140 - Scoop
http://store.summitracing.com/partdetail.asp?autofilter=1&part=SSE%2D950%2D72100&N=700+115&autoview=sku
$40 cheap filter housing
http://store.summitracing.com/partdetail.asp?autofilter=1&part=SUM%2D239441&N=700+4294739245+4294756359+115&autoview=sku
And then it's not even cold air! It's whatever air is there, which would most likely be coming from the engine unless the filter pokes up just enough and I cut the hole just right so it pokes into the scoop.
And then there's this.......
$176
http://store.summitracing.com/partdetail.asp?autofilter=1&part=SUM%2DG3019%2D1&N=700+4294887855+115&autoview=sku
Will this be the riciest thing I can put on my car? Why does it have to make the most mechanical sense? Cold air, large intake, near ram air, filter elements built in, just need to cut a hole. The only saving grace is the car is fast enough to pull something like this off. Especially if I get the black one since the car will have a black hood. Please either slap me from this senseless nonsense or reinforce the alure that is surrounding it.
Like this, but it would be black with a black hood.
Posted: Fri May 01, 2009 10:26 am Post subject: |
Can I talk you up instead?
I've always loved those scoops on older muscle cars. I never thought it would look good on a thirdgen, but that picture you posted is pretty sweet...
Your car is definitely beefy enough to do that, and as long as you can keep the scoop low like in the picture I think you'll be fine.
I say go for it!  _________________ 84 Camaro Z28 - LS1/T56
Posted: Fri May 01, 2009 10:34 am Post subject: |
| Everytime I think about it I want to do it. I've always liked them as well! So now the thread is a poll. |
Do it!  |
Posted: Fri May 01, 2009 11:23 am Post subject: |
I know someone who has a GM fiberglass hood that will give it away if you want to pay shipping It needs some TLC _________________ 2008 GMC Z71
d00012 Member
Posted: Fri May 01, 2009 11:47 am Post subject: |
Its something different. I say go with the scoop, everyone has a cowl it seems. Its not plastic, so I think you're good on it not being "ricey."
This is your 454 motor, right? (saw your cardomain) _________________
Posted: Fri May 01, 2009 12:59 pm Post subject: |
| ya, 454. Not low enough to go with being sneaky so i might as well just hang it out there. |
d00012 Member
Posted: Fri May 01, 2009 1:22 pm Post subject: |
When do you think you'll have that car running? _________________
d00012 Member
Posted: Fri May 01, 2009 1:33 pm Post subject: |
Oh...haha.  _________________
Posted: Fri May 01, 2009 1:36 pm Post subject: |
| Oh ya, just for an update, I discovered that #4 and #6 plug wires were swapped. It's now faster than my lt1 car was.... After I get the gauge sensor in tonight I'll go for a cruise and take a video. I need to double check how it's running anyway. |
Posted: Fri May 01, 2009 1:38 pm Post subject: |
| blue89 wrote: | | #4 and #6 plug wires were swapped. It's now faster |
Sorry man, I've done that too, but the way you phrased it just cracked me up. |
Posted: Fri May 01, 2009 1:41 pm Post subject: |
The only sad part was the fact that other than a little rough idle and the occasional backfire it ran fine! I'd say a 454 on 6 cylinders is faster than my V6  |
Posted: Fri May 01, 2009 1:48 pm Post subject: |
do it.
DO IT!
Posted: Fri May 01, 2009 5:29 pm Post subject: |
Posted: Fri May 01, 2009 6:37 pm Post subject: |
| Yeah, I am not really a fan either. |
Posted: Fri May 01, 2009 7:01 pm Post subject: |
Damn, I was going to be the first one here to get one of those.
or not.  |
Posted: Fri May 01, 2009 7:14 pm Post subject: |
| or better yet, go function. Build a low-profile carb-hat for it, then run it to a cone filter, fitted into a sealed section where the battery would be, and then run a NACA duct, so that you actualy get cold air. |
cameron7710 Member
Posted: Fri May 01, 2009 7:46 pm Post subject: |
i say do it a 454 thirdgen can so pull it off
plus with my sister living up there im sure ill get a car from her when she sees a sweet camaro with one of thoses  _________________
Posted: Sat May 02, 2009 6:52 am Post subject: |
| There just is no good solution to making room. That's one reason why I have never done anything with my car. At least you have a Camaro and can pull of the cowl induction hood better. |
