HEI distributor - non cc to cc interface
PostPosted: Thu Apr 30, 2009 9:24 am    Post subject: HEI distributor - non cc to cc interface Reply with quote
Has anyone put a mechanical/vacuum advance coil-on-cap distributor on their TPI cars? I'm trying to get my 454 dizzy hooked up to the stock computer so I can data log rpm. Mine is pointless (literally, not figuratively) and judging by the diagrams between the HEI 5.0L and the 5.0L non HEI I can tap into one of the 3 wires that come out of the pickup module. Anyone done this?
The diagrams seem to point that the Dist Hi Ref is a 12V pulsed signal to the computer. Seems like I should be able to tie into the coil control wire with a resistor or zener diode to make sure I don't mess up the ecm (flyback voltages are not nice).
PostPosted: Thu Apr 30, 2009 10:11 am    Post subject: Reply with quote
I think the coil in cap dizzys are to physically big to fit behind a TPI motor. But that is mute for you since your BBC-carb.
I did help put a coil-cap setup in a boat a few years ago. 4 wires to hook up and away we went.
PostPosted: Thu Apr 30, 2009 10:42 am    Post subject: Reply with quote
My 86 TPI has a coil in cap distributor.
PostPosted: Thu Apr 30, 2009 11:02 am    Post subject: Reply with quote
really? Wow, I thought I read they were to big Smashy Smashy
PostPosted: Thu Apr 30, 2009 11:25 am    Post subject: Reply with quote
Using my Chevy Power book (GM #24502488) the center engine mounting bolt on the sbc is 15.05" from the rear pin deal and the bbc is 14.93" from the rear pin deal. So they are essentially the same distance from the firewall.
I know ideally I should just get a cc hei distributor. But the gains would be neglagent at this point. Maybe after I get the fuel injection going.
PostPosted: Thu Apr 30, 2009 11:36 am    Post subject: Reply with quote
85 & 86 got large cap cc hei. I think the vettes kept em longer.
90droptoproc
PostPosted: Fri May 01, 2009 10:22 pm    Post subject: Reply with quote
I have a spare 91 350 distributor, needs cap and rotor
