BigBoi4Lyph Member
Joined: 10 Jun 2007 Posts: 233 Location: Olympia, Washington
Posted: Fri Apr 24, 2009 10:58 pm Post subject: manual shift plate/knob/ t5 speedo bullet. |
so im looking for a black shift plate for a manual camaro. with boot.
also black shift knob.
and also in need of speedo bullit assembly for a t5. and possibly a blue(20 tooth) driven gear with the bullit.
thanks! _________________ 87 Camaro Z28 - Iroc-Z |
alloy T56 Elitist
Posted: Sat Apr 25, 2009 12:22 pm Post subject: |
Take Dan's suggestion.
My outer o-ring was bad on my trans and I replaced it with the steel bullet. Hasn't leaked (after I tightened the drain plug back up that is...doh!) since. _________________
BigBoi4Lyph Member
Posted: Sat Apr 25, 2009 3:26 pm Post subject: |
thanks for the sugeastions!
sounds perfect. _________________ 87 Camaro Z28 - Iroc-Z |
