New toy problem 3.1 v6 camaro
kurfbird
PostPosted: Sun Apr 05, 2009 1:44 pm    Post subject: New toy problem 3.1 v6 camaro Reply with quote
Okay the 1991 3.1 v6 had a bad vaccum leak. Looks like some one replaced the heads. painted blue and a new plug cap on one of the back heads.
Pulled compression test on engine was good betweeen 130-150 PSI before doing intake gasket and timing chain.
Just put it back together.
Now here is the problem. No Compression in number 4 cylinder. Have tried adjusting the valves a number of times and still no compression.
Have done both ways that I read about on the TGO board to no avail and have use my 1992 factory sevice manual.
The push rods do move the valves just dont know if they are opening the valves. Since no compression. Is there something I am missing. If the intake gasket was cocked or moved during insulation. Would that casue a no comression issue.
I dont think so but I have to ask. Have done intake on 3.1 before and have never had this problem.
The cylinder is moving manual cranked it and the cylinder does move. Use a screw driver.
Any help would be appricated.
kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com
PostPosted: Sun Apr 05, 2009 4:59 pm    Post subject: Reply with quote
I know the valve adjusting on the v6's is a pita. Are you just getting low compression on it, or just flat 0?
Have you ran it since it was put back together?
kurfbird
PostPosted: Sun Apr 05, 2009 6:59 pm    Post subject: compression Reply with quote
Thanks for replying Just came in got it figured out. Well my friend thanks to him help me with it.
Was just getting 0 but now get great compression. So waiting to ensure all the anti freeze leaks are fixed. Will finished putting it together tomorrow.
Painted the a/c delete box. And back at it after work tomorrow.
kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
PostPosted: Mon Apr 06, 2009 6:47 am    Post subject: Reply with quote
What was the problem?
kurfbird
PostPosted: Mon Apr 06, 2009 9:10 am    Post subject: problem Reply with quote
I adjusted the valfves two tight.
kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
kurfbird
PostPosted: Tue Apr 07, 2009 9:30 pm    Post subject: Next problem Reply with quote
Okay started car ran good then started bubbling in the over flow then oil in the overflow. So Now its a bad head gasket.
SO I went to to the parts store and got a head gasket kit and new bolts. Pulled the heads no cracks or anything out of the ordinary. Installed new gaskets and torque then up to sepcs.
That is the second time that I repalced an intake gasket and then the head gasket went bad.
Almost makes me wish that I would have did the heads in the first palce.
If weather is good and I have the time the intake and everything will be going back together tomorrow.
kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
