best tool for cutting clutch master hole?
BigBoi4Lyph
PostPosted: Mon Apr 06, 2009 4:54 am    Post subject: best tool for cutting clutch master hole? Reply with quote
so i was hopeing to use a circle cutter and then just grind out the oval shape.
but i cant seem to find a metal hole cutter that goes in a drill.
any advise/tips to cutting this area?
also how did you guys cut the tunnels shifter hole? from the bottom or the top?
i have the donnar car still so i can probably take the position of the shifter hole from it and mark it on the top side of mine and cut it out huh?
thanks. Almost their!!!
87 Camaro Z28 - Iroc-Z
PostPosted: Mon Apr 06, 2009 5:19 am    Post subject: Reply with quote
I just used a hole saw to cut my master cylinder hole and a cutoffwheel for the shifter.
BigBoi4Lyph
PostPosted: Mon Apr 06, 2009 5:30 am    Post subject: Reply with quote
just a bi metal hole saw on a drill?
i dont have any air unfourtunatly and i dont have a electric cut off wheel i could probably pick up a harbor freight one for cheep that will work.
i have a saw-all but i would need to start the hole with a series of drill holes ro something.
PostPosted: Mon Apr 06, 2009 6:25 am    Post subject: Reply with quote
Yup.
And a cut-off wheel for the shifter hole.
PostPosted: Mon Apr 06, 2009 9:06 am    Post subject: Reply with quote
...or a sawzall and do it redneck style like I did. Embarassed
If you need to borrow a hole saw BigBoi I have a few laying around you can have no problem.
PostPosted: Mon Apr 06, 2009 9:31 am    Post subject: Reply with quote
I'm so tired of seeing jagged botched 5spd installs! Cut it CLEAN! Then you wont cut yourself when you put the shifter in!
PostPosted: Mon Apr 06, 2009 10:30 am    Post subject: Reply with quote
Nice pair of tin snips on the shifter hole?
PostPosted: Mon Apr 06, 2009 3:33 pm    Post subject: Reply with quote
After I cut my hole I took some tiny black vacuum line, slit it down the side, squeezed rtv inside it and pushed it on the edge of the hole. Makes a nice grommit. Smile
BigBoi4Lyph
PostPosted: Mon Apr 06, 2009 9:45 pm    Post subject: Reply with quote
used a cut off wheel on a drill to start all 4 sides of the tunnle and then a sawzall to finish it purned out nice and staight. looks good.
bought a 1.5 inch hole saw cut the master hole and used some griding buts to oval it out a little bit.
got everything bolted up tranny in and come to find out the master that was seeming kinda weak on the way home took a big crap and only was randomly supplying pressure.
haha not it dosent at all so i tryed a new slave but that didnt help so i get to take out the booster again tommorow and get a new master in their.
other then that this swap has gone very well.
