flea Member
Posted: Wed Mar 04, 2009 10:23 pm Post subject: |
looks like a hose is bulging a bit
J/k |
Posted: Wed Mar 04, 2009 11:35 pm Post subject: |
funny. when is that thing going to roar to life?! i need to come see it once its done!
Posted: Thu Mar 05, 2009 7:05 am Post subject: |
| Last night I got those parts on and I got the shifter linkage fit. Just drilled a hole in the middle of the 700R4 bracket and it lined right up with the bolt on the TH400. Seems to shift fine! So now I need some rubber line for the fuel, some barbed fittings for the regulator, fit the lower radiator hose, and wire the alternator, distributor, and sensors. Shouldn't take that long, right? |
Posted: Thu Mar 05, 2009 7:41 am Post subject: |
Well, if you dont have cash flow it takes a long time to get the parts. But all the time in the world to work on it.
Once you get cash flow, you got no time.
I wanna see some vids of it running as well! How high does the front sit with the extra weight? |
Posted: Thu Mar 05, 2009 7:59 am Post subject: |
| It only dropped the front another 1/4". No biggie. I'm hoping that my since my suspension was too stiff for a V6 that now it will be just right. |
Posted: Thu Mar 05, 2009 8:03 am Post subject: |
| blue89 wrote: | | Shouldn't take that long, right? |
Ask QwkTrip.  |
Posted: Thu Mar 05, 2009 8:25 am Post subject: |
I'm doing far less than he doing though. It ran fine when I took it out of the donor truck! I think that if anyone has some stock exhaust manifolds laying around I'd use them instead of what I have. |
Posted: Fri Mar 06, 2009 9:28 am Post subject: |
| i got all the fuel stuff on last night, kinda stoked! I even have a fuel pressure gauge (a cheap Spekter, but oh well), my upper rad hose is routed and almost done. Just need the bottom rad hose, figure out the exhaust, and wiring! |
Posted: Fri Mar 06, 2009 5:55 pm Post subject: |
Sweeeet! I want to see a BB thirdgen drifting! _________________
Posted: Mon Mar 09, 2009 6:52 am Post subject: |
| I got the heater core hoses on, spark plugs in, tranny cooler on, and was monkey'in with the fuel regulator. Does anyone else have one of these? It's a HOLLEY UNIT and I followed the instructions (figure 2a). I do not understand how this unit works at all. How can the out be an in??? I just don't get and it doesn't seem to be building up enough pressure but that could be the seats of my quadrajet not holding up. |
Posted: Mon Mar 09, 2009 9:33 am Post subject: |
I have that exact same unit on the Merc.
The bottom port is in from the pump, and you have two outs: one on either side. You can run dual lines to a carb that's setup for it, you can run a gauge and a single line as I did in the pic, or just block it off with an NPT plug. |
Posted: Mon Mar 09, 2009 9:44 am Post subject: |
I'm running an in-tank pump and need the return since I'm high pressure. Think my pump/setup is the problem?
I don't think doing a returnless vane pump is going to work. I ran it like Holley said and put the feed into the out of the regulator. Doesn't make sense to me. You seem to have ran it the way I think it should work, not how I need to do it. |
Posted: Mon Mar 09, 2009 11:43 am Post subject: |
| Ah, I had assumed you had a mechanical pump. They do show two different part numbers: a 12-802-1 standard and a 12-803-BP bypass. You might have gotten the wrong one with your kit. |
Posted: Mon Mar 09, 2009 12:56 pm Post subject: |
Dang it. I've already run fuel through it!
How much pressure should a Holley or Quadrajet get? Can't you adjust them to take anything? |
Posted: Mon Mar 09, 2009 1:22 pm Post subject: |
| I'm guessing here, but I'd say 7 -8 psi max. Should be around 5 - 6 psi |
Posted: Mon Mar 09, 2009 3:22 pm Post subject: |
Think about how a carb works... the only thing that shuts off the fuel is the float.... like a toilet. Overpower the pull on the float and arm with pressure and the needle doesn't seal then you get fuel overflowing the bowls.
PSI should be 3-6 roughly. Holley and Q-Jet aren't as tempermental as say a Weber. 1 PSI on a Weber and you're roached. _________________ A redline a day keeps the carbon away! |
90droptoproc Member
Posted: Mon Mar 09, 2009 5:37 pm Post subject: |
what he said |
| 4-5 supposedly is the sweet spot on a quadrajet. 6-7 on a holley. |
Posted: Tue Mar 10, 2009 6:17 am Post subject: |
this carburetor thing is a new but temporary fuel solution for me so I'm learning as I go. Once I get some 30# fuel injectors I'm stuffing them in! Till then I really appreciate the help.
I got the radiator lines ran last night! I also got the fan back in but I didn't snap a pic. So the few remaining things are the exhaust, alt, and distributor! Go me! _________________ E30
