Posted: Thu Mar 19, 2009 9:56 am Post subject: Power Steering Hoses |
So as you know, I have a '74 pump with an '86 box. The '86 high pressure hose left with the V6 so I tried to put the '74 hose to the '86 box. Unfortunately the box side of the hose is different. I don't have a '86 high pressure hose laying around so I'll have to buy one. Does anyone know if the pump side is the same for the various years?
(Good news, I have the rear fluid changed and driveline in. It's down to exhaust directing and wiring up a few things after the PS is done.) _________________ E30
Posted: Thu Mar 19, 2009 10:13 am Post subject: |
| I would just find out what size the fitting is on the 86 box, and take the pressure hose into a hydrolic shop and have them braze the correct fitting onto your hose. Might be cheaper than buying a new hose. |
Posted: Thu Mar 19, 2009 10:53 am Post subject: |
| Dewey316 wrote: | | I would just find out what size the fitting is on the 86 box, and take the pressure hose into a hydrolic shop and have them braze the correct fitting onto your hose. Might be cheaper than buying a new hose. |
+1 on this. Shouldn't be more than 10-15 bucks to have it refitted and flanged, assuming the length is correct. |
Posted: Thu Mar 19, 2009 11:39 am Post subject: |
| Didn't know they could do that. The 86 box has what looks like a cup on the end. So they would braze on a new rigid part of the hose like a ferrel and leave the rubber alone? |
Posted: Thu Mar 19, 2009 5:37 pm Post subject: |
Or make you a whole new piece either way. _________________ A redline a day keeps the carbon away! |
kurfbird Member
Posted: Thu Mar 19, 2009 8:14 pm Post subject: High pressure hose |
I ahve a high pressure hose from a v6 _________________ kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com |
