Posted: Fri Mar 13, 2009 8:52 pm Post subject: |
| It is a truck-arm setup, they run a similar style in Nascar. It has some advantages, like everything else, it has some disavantages. |
Red Bird Member
1991 Pontiac Firebird
Posted: Fri Mar 13, 2009 9:43 pm Post subject: |
I saw it at FormulaD seattle a couple of years ago. i dont think it made it to the top 36 and it had a different paint scheme i think it was dark blue. still parked with all the falken rides, and still a viscious beefcake beast! _________________ 1991 Firebird L03 T-5 |
Posted: Fri Mar 13, 2009 10:14 pm Post subject: |
how odd...
I was just reading about the options for eliminiating the Torque arm on TGO, and this type was mentioned. Nice to be able to see what they're talking about. _________________
Posted: Fri Mar 13, 2009 11:13 pm Post subject: |
If you have control arms strong enough and mount them in two places at the rear you can eliminate the torque arm. Still need a panhard. Not worth the work. Ever. _________________ A redline a day keeps the carbon away! |
Posted: Wed Mar 18, 2009 7:47 am Post subject: |
| I saw a kit for the double mounted lca a while ago and may have posted it here somewhere. It didn't seem like the best design since the arm would be super short and cause pinion angles to be weird. |
Posted: Wed Mar 18, 2009 6:05 pm Post subject: |
I remember a thread awhile ago that showed a kit to get rid of the panhard bar. An OLD kit from someone that replaced the lower control arms and Y'd out. Kind of like 4 wheel drive lift kits that do the longarm conversion. One pivot on the body side and two mounts on the axle using the same LCA. The thread I remember had the guy showing pictures of the LCA cracking in half because it rusted out from a crack or something in the powdercoat/paint. This was awhile ago though. _________________
