GREG DAVIDSON Member
Posted: Thu Mar 05, 2009 10:28 pm Post subject: so i steamcleaned my engine bay........ |
with antifreeze anyone know what the technical name for this is i need to try and find a new one the one on my parts car was bye passed so im going to borrow the one off the red car till i get it figured out heres a pic of the broken one... |
Posted: Thu Mar 05, 2009 10:43 pm Post subject: |
| It's the heater valve. Should be fairly cheap at a parts house.. like $15 or so. |
Posted: Thu Mar 05, 2009 10:50 pm Post subject: |
Heater diverter valve. It diverts the flow of water to the heater core when temperature is selected to cool. I think I have an extra sitting around somewhere. _________________ 92 Camaro
Posted: Thu Mar 05, 2009 11:16 pm Post subject: |
thanks guys i'll have to track em down tomarrow the one off the red one is kinda iffy to but it should do till i can get another one _________________
Posted: Thu Mar 05, 2009 11:54 pm Post subject: |
We keep one in stock at Knecht's I believe... _________________
'88 FORMULA |
Posted: Fri Mar 06, 2009 12:11 am Post subject: |
i wish Knecht's had a web site you could look parts up on like the rest of the parts stores lol auto zone doesnt stock it scmucks does i'll have to call
Knecht's in the am, sorry but all the schucks stores in this town are full of idiots and their my last resort parts house again thanks for the help guys |
alloy T56 Elitist
Posted: Fri Mar 06, 2009 12:33 am Post subject: |
If Knecht's doesn't have one call Schucks and ask for Factory Air part# 74805. It's a part that's stocked in most of their stores. That way no need to deal with morons.
And if you do try to take the one off the other car it will probably break. They get brittle and break easily after a few years. _________________ Member of the "Elite T56 Club" , big brake club, and "burgundy" (not red or maroon) car owner.
Posted: Fri Mar 06, 2009 1:03 am Post subject: |
You could just delete the thing along with those hoses with one 3/4 bypass cap, a 5/8 90* coolant fitting, and some clamps. Cleans it up under the hood nicely.  |
Posted: Fri Mar 06, 2009 1:05 am Post subject: |
| fiveoformula wrote: | You could just delete the thing along with those hoses with one 3/4 bypass cap, a 5/8 90* coolant fitting, and some clamps. Cleans it up under the hood nicely.  |
i thought about that to but i dont know yet |
Posted: Fri Mar 06, 2009 1:57 am Post subject: |
| Its pretty easy dude! I think you'll like the looks of it! |
Posted: Fri Mar 06, 2009 7:16 am Post subject: |
x2
Cleans up that area a little. I've had to bypass my gf's Jeep and my moms New Yorker ($30 and $45). |
Posted: Fri Mar 06, 2009 7:40 am Post subject: |
When mine broke it was $35. So I spent $5 on heater hose and a cap and works fine.
Some people say that your A/C wont work as well because the heater core will always have fluid, but I never saw any difference.
Make sure to cap that vacuum line too. _________________ A redline a day keeps the carbon away! |
Posted: Fri Mar 06, 2009 3:15 pm Post subject: |
ok since my parts car had everthing byepassed i should have all the parts to do that couls someone send me some picks of how you did it i never really look at how my parts car was set up  |
Posted: Fri Mar 06, 2009 3:27 pm Post subject: |
| it doesn't really matter how it goes. the hoses look like this == so connect them. Heater core shouldn't care too much how the water goes through. |
Posted: Fri Mar 06, 2009 4:54 pm Post subject: |
Cap the vertical Tee-d off line from the lower Hard Line.
Run one line from the intake to the heater core, run from the heater core to the rad.
Bypass the throttle body as well while you do this. _________________ A redline a day keeps the carbon away! |
Posted: Fri Mar 06, 2009 5:43 pm Post subject: |
cool thanks guys! btw neither of mine have a coolant line running to the t.b. _________________
Posted: Fri Mar 06, 2009 5:50 pm Post subject: |
| GREG DAVIDSON wrote: | t couls someone send me some picks of how you did it i never really look at how my parts car was set up  |
You connect these with the 90*
And then you cap the hard line.
Posted: Fri Mar 06, 2009 5:58 pm Post subject: |
On my bird the hardline was routed all the way down the frame rail. I just cut the T'd section off and ran just a bit longer hose and it was still bolted to the rail. One less cap you'd have to worry about. Not like it's a big issues eitherway. _________________
