Posted: Mon Feb 16, 2009 5:06 pm Post subject: brake master cylinder compatibility |
Can i use a master cylinder from a 4th gen?
does anyone have one lying around? mine is leaking out under the reservoir.
Posted: Mon Feb 16, 2009 5:17 pm Post subject: |
You can. I'd try to get one from the later 4thgens to get the low fluid switch built into the resevoir.
Actually, I think I have a couple thirdgen ones laying around. Or you could always try rebuilding yours.  |
Posted: Mon Feb 16, 2009 6:52 pm Post subject: |
Bolts right up to the booster. Only issue I had was thread depth for the flare fitting. I used a set of adapter lines from NAPA when I installed my adjustable prop valve, and their fitting that is the size for the rear didn't have enough threads on it to seal the flare, I took the stock fitting off my old line and flares it onto the NAPA line.
I've still got my stocker lying around in the garage. _________________ 92 Camaro
Posted: Mon Feb 16, 2009 10:35 pm Post subject: |
He's converted to a disc rear.
I got my master from NAPA and it came with the reservoir. I tried used and got one that leaked badly so I sucked it up and bought a new one and don't regret it. 2002 Camaro SS. |
90droptoproc Member
Posted: Wed Feb 18, 2009 4:03 pm Post subject: |
may want to check that your fittings are metric _________________
Posted: Wed Feb 18, 2009 6:30 pm Post subject: |
Mid-late Thirdgen fittings are metric bubble flare.
I recommend new master cylinders always. Those crazy ... uh.... rebuilders.... don't seem to be able to read the blueprints. _________________ A redline a day keeps the carbon away! |
90droptoproc Member
Posted: Wed Feb 18, 2009 9:35 pm Post subject: |
I know my 82 had standard thread, had to cut the ends and re flare for new fittings when I bought a new master _________________
Posted: Thu Feb 19, 2009 7:55 am Post subject: |
| You most definetly do have to use different piping. What I did was used the rear piping of the 3rd gen and the front piping from the 4th gen. That way I only had to put new nuts on the proportioning valve and front tee. |
