Single Electric fan.
Goto page 1, 2, 3  Next
PostPosted: Sun Jun 08, 2008 10:05 pm    Post subject: Single Electric fan. Reply with quote
Getting ready to do this.
I tried to do a little research on TGO and figure this out.
I have two relays. One has no pigtail, the other one is the one the mounted on the firewall, it has ports A-E.
A--Dark green wire
B--Black wire
C-Light Green wire
D--Black wire
E--nothing
I would assume that the black wires in ports B and D are Grounds, and the Green ones are my hot wires.
The fan itself has a plug with two large black 10ga wires. I would assume one is power and one is ground.
Would I just run one hot wire and one ground to the fan, and one hot wire and one ground to a switch?
I'm not very good with wiring, so any help is appreciated.
PostPosted: Sun Jun 08, 2008 10:17 pm    Post subject: Reply with quote
lol, I just got done rewiring my fan relays this afternoon too. Laughing
On mine I have dual fans, so it's a little different, but this is the stock wiring setup:
PostPosted: Sun Jun 08, 2008 10:19 pm    Post subject: Reply with quote
What pins do those corespond with. Your relay should have pin number listings, you can tell what is what by those.
PostPosted: Sun Jun 08, 2008 10:40 pm    Post subject: Reply with quote
Ok. Here's what plugs into the fan:
I have ports A and B
A---Black wire
B---Black/Red wire
PostPosted: Sun Jun 08, 2008 10:51 pm    Post subject: Reply with quote
If you don't have any relay wires or harness left, it should be fairly simple to nick a junkyard one, or even build one yourself. All you would need is a thermal switch, and a fuse, and a relay.
PostPosted: Sun Jun 08, 2008 10:55 pm    Post subject: Reply with quote
I guess I am not sure what you are trying to find out. are you just trying to get the fan to turn on manual, or are you hooking in a temp switch also, etc.
PostPosted: Sun Jun 08, 2008 10:56 pm    Post subject: Reply with quote
I'm thinking that's kind of what's going to have to happen....
I have the primary and what I would guess is the secondary relay, Two wires to the fan and the fan itself.
Its going to have to be a kind of stand-alone system that is either wired directly into the ignition, or to the battery.
PostPosted: Sun Jun 08, 2008 10:57 pm    Post subject: Reply with quote
Think of it like this:
i'm trying to take a car that basically doesn't have any of the stuff to run an electric fan, and I want to run one to it.
If I have to power it with a switch inside, that's ok. I'd prefer one that runs of cylinder head temp to switch it on, but I'm not sure if I can do that with what I have.
PostPosted: Sun Jun 08, 2008 11:01 pm    Post subject: Reply with quote
DON'T power it through the switch.
What you need to do is wire it like the TBI cars. Pull up the TBI wiring diagram for the cooling fan in your haynes manual. Basicly, the thermo switch will ground the ciruit to close the relay, that turns the fan on. You can then put a manual switch inline with that, to ground that circuit manual, so you can overide the temp switch if you need.
--John
PostPosted: Sun Jun 08, 2008 11:03 pm    Post subject: Reply with quote
hmm. I've heard not to power it through a manually controled switch is a good idea.
I'm thinking something simple like this would work;
PostPosted: Sun Jun 08, 2008 11:05 pm    Post subject: Reply with quote
So if this makes sense...
Basicly switched and fused 12v power will go to D, F will go to the temp switch in the head, and also a manual switch if you want.
E will get 12v FUSED power, and A will go to the + side of the fan (B), and then you ground the other side of the fan (A)
EDIT:
Ahh, you responded at the same time I did. Yes, you are basicly getting the idea, the termo switch will ground your trigger side of the relay, which will power the fan.
PostPosted: Sun Jun 08, 2008 11:10 pm    Post subject: Reply with quote
I have to big 10ga wires, that I think are wired to my ignition source with the key in the "on" position.
I'll take the Multimeter to them tomorrow and see if they are. If they are a constant runner, wouldn't that make my fan run all the time, or would that be regulated by the temp switch? I know that Paul and I powered mikes Wideband control with them when i was tuning last year.
PostPosted: Sun Jun 08, 2008 11:13 pm    Post subject: Reply with quote
No, the fan will only get power when the relay is on, which will only happen when you temp switch gets to a certain point. You run 12v power (heavier gauge) to one side of the realy, the otherside to the fan. This keeps the fan from running all the time, because the fan only see's voltage one the relay has been triggered.
--John
PostPosted: Mon Jun 09, 2008 6:33 am    Post subject: Reply with quote
That should work fine. What type of relay do you plan to use? That drawing, though typical, depicts a bosch relay which may not be heavy duty enough to run your fan. Maybe you could find which terminals of your fan relay corrospond corrospond to 30, 87, 85, 86 of a typical bosch relay, ten go from there. Also, on that drawing, you could add another wire to terminal 86 and route a ground from a switch to have manual control of your fan and wouldn't hurt anything.
EDIT:
On your fan relay with terminals A - E, compared to the relay in this digram, A=fan pwr from 87, B & C=not used, D=switched 12V (ign) from 85, E=12V (batt) from 30, F=ground from 86.
PostPosted: Mon Jun 09, 2008 6:53 am    Post subject: Reply with quote
-4 wires.
-2 fat wires hook from fan to battery +.
-2 smaller wires.... Ign power to Small wire. Small wire to Block Switch AND to manual switch. From each switch run to ground.
Doesn't matter which fat wire is which and which smaller wire is which. You run a switch to control the relay. You don't run a manual switch to control the fan. See how fat those wires are? Lots of amperage running through that will burn up the switch.
Make sure the relay works.
PostPosted: Mon Jun 09, 2008 7:05 am    Post subject: Reply with quote
You cleared that up pretty good Paul. Kinda simplified version of what I was trying to say.
PostPosted: Mon Jun 09, 2008 7:11 am    Post subject: Reply with quote
Chris called me last night during the posting. I figured out what was going on. His car had 2 relays , and he cut the 2nd half of the harness, the relay he is talking about doesn't have the fat wires. I think the relay he has left is probably the override for the AC turn-on. He is missing the harness part that had the heavy gauge wire that ran to the battery.
I'm stopping by over there on my way home, to get his squared away with how to run it. We are just going to put in a thermo switch and 1 relay so that it works for him.
--John
PostPosted: Mon Jun 09, 2008 6:35 pm    Post subject: Reply with quote
If anyone else is interested in doing this conversion, Schucks sells the relay and thermal switch kit for around $40. Turbo_jimi just bought one to replace the manual switch we installed when we converted his Z28 to an electric fan.
Hey, heres a helpful hint: if the fan blows the wrong direction, reverse the polarity. Common sense, I know, but you'd be amazed how many people can't figure that out. Smile
PostPosted: Mon Jun 09, 2008 8:47 pm    Post subject: Reply with quote
Guess I never thought about that. LOL
Mine seems to do the job so it must work.
What's the temp on at for that schmucks kit?
PostPosted: Mon Jun 09, 2008 8:51 pm    Post subject: Reply with quote
They have the Hayden adjustable one, or preset at 185*:
http://www.partsamerica.com:80/ProductList.aspx?PartType=843&PTSet=A
Page 1 of 3
