corey davidson Member
1986 Chevrolet Camaro
Posted: Thu Feb 12, 2009 1:06 pm Post subject: tranny coolers |
ok so we got the motor in but forgot to put the tranny coolent lines back on is there a way we could do this with out having to drop the tranny again |
Posted: Thu Feb 12, 2009 1:50 pm Post subject: |
Is this for a 'real' tranny cooler or the factory setup that runs coolant through the sandwich plate at the engine oil filter?
Posted: Thu Feb 12, 2009 1:51 pm Post subject: |
| idk they are metal lines that came off my 700r4 |
Posted: Thu Feb 12, 2009 1:57 pm Post subject: |
| yea run from the radater to the tranny pretty much by the oil filter |
Posted: Thu Feb 12, 2009 2:16 pm Post subject: |
It's been awhile since I messed with a 700, but I seem to remember that the coolant lines were on a downward angle, and you could snag them without tilting the tranny down any.
As far as what Mike was saying though, unless you really like swapping transmissions, you need to invest in an auxiliary cooler. |
Posted: Thu Feb 12, 2009 2:33 pm Post subject: |
| ok thanks we are gonna try to run the lines and hopefull do a start up tonight |
Posted: Thu Feb 12, 2009 4:46 pm Post subject: |
You don't have to pull the trans to do it. A good flare nut wrench will come in handy. _________________ A redline a day keeps the carbon away! |
Posted: Thu Feb 12, 2009 5:22 pm Post subject: |
| blue89 wrote: | | Replace it all with rubber line. Don't forget to flare the ends! I can't stand those hardlines anymore. |
Rubber line has a nasty habit of melting, tearing, slicing, and generally leaking. _________________ A redline a day keeps the carbon away! |
GREG DAVIDSON Member
Posted: Thu Feb 12, 2009 5:24 pm Post subject: |
he's just being lazy and not wanting to try and put the lines back up i nay have to try myself |
Posted: Thu Feb 12, 2009 5:45 pm Post subject: |
im sick thats y im lazy  |
Posted: Fri Feb 13, 2009 8:48 am Post subject: |
| Meh. If you do as much as you can with the hardline and keep the rubber forward of the exhaust you'll be fine. Makes it so much easier. |
Posted: Fri Feb 13, 2009 10:34 am Post subject: |
| blue89 wrote: | | Meh. If you do as much as you can with the hardline and keep the rubber forward of the exhaust you'll be fine. Makes it so much easier. |
In my experience it is far easier to bend hardline into shape than it is to route and secure rubber lines so they stay out of the way. But whatever works, I guess.  |
Posted: Fri Feb 13, 2009 11:20 pm Post subject: |
| ok this thing is just being a pain now if it doesnt get beat on to heavely would it be ok to block off the cooler lines for the trans ? i knnow how these 700R4s are |
Posted: Sat Feb 14, 2009 10:06 am Post subject: |
| Quote: | | ok this thing is just being a pain now if it doesnt get beat on to heavely would it be ok to block off the cooler lines for the trans ? i knnow how these 700R4s are |
NO NO NO NO NO NO
You MUST have a cooler or you'll burn up the trans real quick. Be patient and don't be afraid to bend the lines a little to get them to fit. If you're struggling with the end at the trans, remove the crossmember and lower the trans down some with a jack to give you better access. _________________ A redline a day keeps the carbon away! |
Posted: Sat Feb 14, 2009 10:13 am Post subject: |
| did that theres still no room dm i hate automatics |
Posted: Sat Feb 14, 2009 10:47 am Post subject: |
It's no where near impossible. But sometimes they do fit you. It's also easier to unhook them from the radiator if they aren't already. _________________ A redline a day keeps the carbon away! |
Posted: Sat Feb 14, 2009 10:49 am Post subject: |
yea got one in one to go if it was'nt for this trans this car would be down the road buy now  |
Posted: Sat Feb 14, 2009 11:01 am Post subject: |
dam autos  |
