how to break into a camaro?
PostPosted: Sun Jan 18, 2009 3:40 pm    Post subject: how to break into a camaro? Reply with quote
ok it finally happened i locked my onley set of keys in my camaro Embarassed and i really cant afford to pay a locksmith to come do it so i need some ways to get in.some thing that might help is i have the hood open and the door isnt closed completely but enough to lock the door
PostPosted: Sun Jan 18, 2009 3:43 pm    Post subject: Reply with quote
If you were in Tacoma I'd say just wait...
PostPosted: Sun Jan 18, 2009 3:50 pm    Post subject: Reply with quote
OK that probably wasn't very helpful.
Power locks??
Try a coat hangar between the window and seal to hit the "unlock" button.
If it were mine tho, I'd just open the hatch, as its held shut by the weight of a gallon of water tied to it. Crying or Very sad
PostPosted: Sun Jan 18, 2009 4:44 pm    Post subject: Reply with quote
ok so after about a hour of picking at the hatch release with a every long strait edge i noticed that my check engine light was on which meant the keys were on turned to accessories it then look me like half a second to hit the power window switch and roll it down Rolling Eyes Embarassed so now i feel stupid but tomarrow i will be going and geting a spare key made cause for some reason i have a spare for eveything but the door lock Rolling Eyes
Ha ha
PostPosted: Sun Jan 18, 2009 5:31 pm    Post subject: Reply with quote
Perfect first reply. Laughing
PostPosted: Sun Jan 18, 2009 5:39 pm    Post subject: Reply with quote
If for some reason you do this again. Take a something long and thin. .. on the pass side. Shove it down between the door skin and the window back by the lock. Just push down on the lock rod.
PostPosted: Sun Jan 18, 2009 6:52 pm    Post subject: Reply with quote
ill keep that in mind thanks
PostPosted: Sun Jan 18, 2009 7:19 pm    Post subject: Reply with quote
If for some reason you do this again HAVE ANOTHER SET OF KEYS. Laughing I thought we covered this with somebody else about a month ago. Wink
PostPosted: Sun Jan 18, 2009 7:41 pm    Post subject: Reply with quote
haha im taking care of that tomorrow ima have my brother in law make me up a spair
PostPosted: Sun Jan 18, 2009 8:01 pm    Post subject: Reply with quote
Okay, I'll make a confession. Just before Christmas I locked myself out of the Jeep at work. My wife had to come open it up for me. I haven't done that in at least 15 years!
I like the way my '94 Vette was set up. If the key fob jiggled it would send out a short range signal to the car. If you walked out of range then the car would lock. Once you walked back in range it would unlock again. This made it impossible to lock myself out. The one time I left my keys in the car all I had to do was rock the car and the doors unlocked. Now that doesn't count as locking myself out... I just left my keys in the car. Very Happy
Now the real problem I've had the last few months is the new locks on the house. I swapped out all our locks for better units and got the kind where you can open the door from the inside whether or not the door lock is set. After locking myself in the garage about 4 times, and my wife doing the same about 10 times, I finally just left a key in the door handle. Laughing
PostPosted: Sun Jan 18, 2009 8:23 pm    Post subject: Reply with quote
ya had those kinda house locks at one point it really sucks when u go to grab the news paper in your boxers at 6 in the moring and forget about that dam door lock Embarassed
PostPosted: Sun Jan 18, 2009 8:39 pm    Post subject: Reply with quote
I haven't done it going outside yet. Just into the garage. But I did leave the front door ajar one day. When I opened the screen door (with glass in it for winter) it sucked the inside door closed. DOOOOHHHH!!!! Very Happy
PostPosted: Sun Jan 18, 2009 9:41 pm    Post subject: Reply with quote
My stepdad took the 'vette to up to Seattle the other day. Evidently he started it up, ran inside to grab something and went on his merry way.
After he got there, he went on his errands and came back to the car. Realized he left the fob on the counter at home. DirtySteve had to drive up there to give him a fob to start it up. Laughing
I was under the impression it would kill the car if he drove away without the fob but I guess not!
PostPosted: Sun Jan 18, 2009 10:34 pm    Post subject: Reply with quote
well..... i lock my self out of my car alot Sad
but i learned to keep a spare in my wallet, that works really good!
Cool (then no one has to know either)
-Donald
PostPosted: Mon Jan 19, 2009 5:55 am    Post subject: Reply with quote
I too keep a spare in my wallet. Although one time I did lock myself out of my car with my keys in the ignition and my wallet sandwiched between the seat and center console. Duh
On the other hand, after a whole day of practicing, I can now break into my camaro in under 10 seconds with a coat hanger. it's scary how easy it is.
PostPosted: Mon Jan 19, 2009 7:23 am    Post subject: Reply with quote
i can unlock the 86 faster with a ruler then i can with a key. the GTA is harder because it has power locks.
dlp
1990 Chevrolet Camaro IROC-Z
PostPosted: Mon Jan 19, 2009 7:08 pm    Post subject: Reply with quote
I was born in WA but went to HS in Sacramento CA. I have only done this on my car but it is common knowledge for theives, wich I happened to know a couple of in HS.
It is alot easier to do this on t-top cars. Pry the top of the window out from the lip of the weather seal with a screw driver / key / what ever you have. Then get your fingers rapped over the top of the window and gently pull towards you with one hand. Take the other hand and reach in and hit the unlock button. C4 corvettes are just as easy to break in to. I can mess up your window guides if you pull to far, but if you have to do it, it works. I have done it twice on my car.
PostPosted: Tue Jan 20, 2009 3:31 pm    Post subject: Reply with quote
Every group needs one good criminal to help with these issues of misfortune. Laughing
PostPosted: Tue Jan 20, 2009 3:39 pm    Post subject: Reply with quote
I watched a tow truck driver break into Mom's Dodge Stratus. All he had to do was put an inflatable bag in between the door and b-pillar, inflated the bag and reached through with a long, heavy wire to hit the unlock button. $76 for about 10 seconds of work Shocked
This would be much easier on 3rd gen since the windows have no frames around them.
PostPosted: Tue Jan 20, 2009 4:05 pm    Post subject: Reply with quote
that's exactly what AAA guy did when i locked my keys in the car! I was shocked at how fast he pulled it off!
