more and more problems....
91camaro_rs
PostPosted: Wed Jan 14, 2009 10:43 pm    Post subject: more and more problems.... Reply with quote
ok so i was drivin to school the other day and was like OMG i looked at my oil pressure sensor and it was like a tiny bit away from zero and was like oh crap Shocked so after school i took it to the eagle tire/automotive and left it there overnight cause they were full. so in the morning i get a call and they said my oil sending unit was bad, my oil pressure sensor was bad and my valve covers leak, and my distributor needs a new o ring cause its leakin. so i had top priority done cause of the cost. so i had the pressure sensor and sending unit fixed. i already knew the o-ring had to be replaced from when i took it in before. so...i was drivin my car and i noticed that when i idle and idleing while moving just a little bit or braking it starts to rev itself like go down to 500 then to 1000 up and down up and down until the car stops then it stays at like 650 but i was in the safeway parkin lot and it starts revvin itself and so i just let it do its thing and it went below 500 and died...so idk what to do cause it did it a little bit when i noticed the pressure was low but not before then when all was good.
anyone have any ideas of what could be making it do this?
and also my headlights...if i keep the hi-beams on too long they all start flickering Mad ...i think all the lights is like overloading the fuse or something...ill have to check it but i might have to wire my headlights straight to the battery or something to prevent the computer from messin with the lights
and one of my brand new shocks went out but thank goodness for lifetime warranties and summit racings fast shipping, i already have the replacement
and last...my wheel bearings are still bad...i really need to get em down, sounds like a space ship landing when i turn Laughing
