Check this out
PostPosted: Sun Jan 04, 2009 8:15 pm    Post subject: Check this out Reply with quote
So I mentioned in another thread that my Camaro had some sort of bad inbalance thing going on in the engine. Well today I busted her out of a pile of snow and took a look at it. The harmonic balancer seperated the outer ring from the hub and was just riding on there loose. I snagged the balancer off the GTA sitting here and she's good as new again.
Then I went sideways to celebrate!Thumbs up
PostPosted: Sun Jan 04, 2009 9:12 pm    Post subject: Reply with quote
Did you install it with a hammer?? Wink At least it was a fairly simple fix.
PostPosted: Sun Jan 04, 2009 9:25 pm    Post subject: Reply with quote
Do those generally wear out easily?
'88 FORMULA
PostPosted: Sun Jan 04, 2009 11:19 pm    Post subject: Reply with quote
Not unless you install them with a "Hammer" Pokey pokey
PostPosted: Sun Jan 04, 2009 11:27 pm    Post subject: Reply with quote
Laughing so hard it hurts
Actually, old ones do it sometimes. Rubber between the two pieces dries up and cracks. Not something to get too worried about though.
PostPosted: Sun Jan 04, 2009 11:32 pm    Post subject: Reply with quote
pfff, a little JB Weld and it is good as new.
PostPosted: Mon Jan 05, 2009 7:23 am    Post subject: Reply with quote
You know the old 327 cranks didn't have a threaded hole. The specified means was installing with a hammer.
PostPosted: Mon Jan 05, 2009 8:31 am    Post subject: Reply with quote
I installed the new one with a hammer, at least until I could enough threads on the bolt engaged to run it on. Just hit the hub, not the outside ring.
PostPosted: Mon Jan 05, 2009 11:15 am    Post subject: Reply with quote
Whoa. Yikes. Could it have walked off if left like that?
PostPosted: Mon Jan 05, 2009 5:08 pm    Post subject: Reply with quote
Shocked
Good thing you caught that when you did. That could have been very nasty, and a much more expensive fix.
