Jason_Culbertson Member
1982 Pontiac Trans Am
Posted: Sun Dec 28, 2008 6:03 pm Post subject: CHEYMAD this post's for you |
ok i was talking to dewey on msn and he said you were the guy to talk to about carb's so HERE it go's...i need to know what would be a good carb to use on my 305? in between 450 and 600cfm _________________ ****______****
___/,__;i__ \
[___ _ ____;.ŻŻŻl
\_(O)______(O)_/
"Smoke tires not drugs"
VW and Audi tuner on Forza 3
Last edited by Jason_Culbertson on Sun Dec 28, 2008 10:34 pm; edited 1 time in total |
Posted: Sun Dec 28, 2008 6:10 pm Post subject: Re: CHEYMAD this post's for you |
| Jason_Culbertson wrote: | so were it go's...
I can help some, it goes right in the middle, between the engine and the hood!!
sorry  |
Posted: Sun Dec 28, 2008 6:36 pm Post subject: Re: CHEYMAD this post's for you |
| rjmcgee wrote: | | Jason_Culbertson wrote: | so were it go's...
sorry  |
holy crap i just noticed that, i feel DUMB  _________________ ****______****
___/,__;i__ \
[___ _ ____;.ŻŻŻl
\_(O)______(O)_/
VW and Audi tuner on Forza 3 |
cameron7710 Member
Posted: Sun Dec 28, 2008 6:51 pm Post subject: Re: CHEYMAD this post's for you |
sorry  | hehe got to befor me  _________________
Posted: Sun Dec 28, 2008 7:17 pm Post subject: |
Is the car still a 700r4? If it is a quadrajets going to be the easiest one to set up on it. Holley will give you the most power, but their 700r4 brackets wouldnt work for me. So it cost me $120 for a bowtie overdrives kit to make it work. An afb/edlebrock is going to be the most dependable carb of the bunch, but will give up power to the holley, and mileage to the quadrajet. Also if you're going from efi or electronic carb remember you'll need a non ecm distributor and a torque convertor lockup kit.
The holley and edlbrock will require an adapter plate, even on a performer intake, so take hood clearance into account.
Reason the quad is easiest is they used them on these cars, so all the parts are out there to make it work. The quads are also variable in size, so doesnt matter too much if its too big. Otherwise i'd stick to a 600cfm size in either of the other brands.
The AFB style carb is the easiest to tune, and it will hold the tune when you're done. The holley is the most tuneable carb, but it will change with the weather. And the quad can be tuned but its a real pia, luckily they just generally work as is. |
Posted: Sun Dec 28, 2008 10:36 pm Post subject: |
should i just rebuild the quad? _________________ ****______****
___/,__;i__ \
[___ _ ____;.ŻŻŻl
\_(O)______(O)_/
Posted: Sun Dec 28, 2008 11:12 pm Post subject: |
| If the throttle shaft isnt all worn out, then that would be easiest. You'll get the best mileage and have nearly all the performance of the other carbs. They're simple to rebuild too. Theres a few performance tweaks you can do too. |
Posted: Mon Dec 29, 2008 12:19 am Post subject: |
well next month im getting a BIG check so ill give you a shout about thouse "mod's" and the rebuild. thanks for all the help _________________ ****______****
___/,__;i__ \
[___ _ ____;.ŻŻŻl
\_(O)______(O)_/
Posted: Mon Dec 29, 2008 11:10 pm Post subject: |
Just a tip for when you rebuild a carb,
Clear off the whole work bench you will be using. You will need WAY more space than you think. Then, cover the whole thing in newspaper. Place the carb on the far right side of the bench and take off a piece. place that piece on the newspaper right above the carb. move the assembly to the right and repeat.
when you get to the far side of the bench and realize that your carb is in a bajillion pieces you will be very happy that you left it all in the order you took it apart in. Then you take a deep breath and start putting it all back together again with the new pieces and PRAY YOU DON'T HAVE PIECES LEFT OVER
Posted: Mon Dec 29, 2008 11:54 pm Post subject: |
| 83Z28BlackBetty wrote: | Just a tip for when you rebuild a carb,
~JAKE |
That's about the exact thing I did when I rebuilt the T56. Just layed it on the table exactly how it came out of the case (along with lots of pictures) |
Posted: Tue Dec 30, 2008 4:01 am Post subject: |
ill jsut pay my dad a beer or two to help me a bit  _________________ ****______****
___/,__;i__ \
[___ _ ____;.ŻŻŻl
\_(O)______(O)_/
Posted: Wed Dec 31, 2008 12:58 am Post subject: |
~JAKE |
ah, I wasn't the focused with the two DP's I rebuilt.
labeled ziplock bags work just as well, since I had limited space to work with. _________________
