Check out my car. What do you think?
beandipkilla
New Member
PostPosted: Sun Dec 28, 2008 8:23 am    Post subject: Check out my car. What do you think? Reply with quote
Hope you like it. not much yet.
http://www.cardomain.com/id/beandipkilla
It is better to remain silent and be thought a fool than to open one's mouth and remove all doubt.
PostPosted: Sun Dec 28, 2008 10:15 am    Post subject: Reply with quote
Looks like a straight body on her, has some potential. Looks better than some of our others started. Don't see many with a sun roof.
PostPosted: Sun Dec 28, 2008 11:40 am    Post subject: Reply with quote
Looks pretty good man. Do you have plans for her?
BTW, welcome to the Crew.
Jason_Culbertson
1982 Pontiac Trans Am
PostPosted: Sun Dec 28, 2008 5:25 pm    Post subject: Reply with quote
ive NEVER seen one with a sun roof
****______****
___/,__;i__ \
[___ _ ____;.ŻŻŻl
\_(O)______(O)_/
"Smoke tires not drugs"
VW and Audi tuner on Forza 3
View user's profile Send private message Visit poster's website MSN Messenger
PostPosted: Sun Dec 28, 2008 6:50 pm    Post subject: Reply with quote
iv seen a few of course not a factory option
nice car btw, lots of potential
beandipkilla
New Member
PostPosted: Sun Dec 28, 2008 10:45 pm    Post subject: Reply with quote
plans for her rigth now is intake, maybe maybe a if i ca a change from a 2bbl to a 4 bbl if possible if they make chips put one in any advice i really don't have the money for a swap
PostPosted: Mon Dec 29, 2008 8:19 am    Post subject: Reply with quote
So it is a 305 5sp? Being that it is also an 82 I'm sure there are lots up stock upgrades to do. Are all of the white area's around the hood and roof because the paint chipped off? Looks like a good starter car for sure. Welcome to the Crew.
Jason_Culbertson
PostPosted: Mon Dec 29, 2008 8:55 am    Post subject: Reply with quote
na i think he said a 2.8 V6
****______****
___/,__;i__ \
[___ _ ____;.ŻŻŻl
\_(O)______(O)_/
beandipkilla
New Member
PostPosted: Mon Dec 29, 2008 10:40 am    Post subject: Reply with quote
yea its a 2.8 v6 its not chipped its primed and sanded already just needs a coat of paint in the front and the roof
PostPosted: Mon Dec 29, 2008 11:09 am    Post subject: Reply with quote
Ah, that's right. Very Happy
I wouldn't recommend it. Not unless you get some 2.8L heads from an 86+ car and then port/polish with a gasket match. You might want to get rid of that Rochester carburetor too. That older 2.8L stuff is just given away so you can get 86+ parts cheap. As far as I know, all the 60V6 stuff has factory forged rods and crank and should be good to turn 7000rpm. So update the valve train and spin that sucker up after the head upgrade and intake mod's.
PostPosted: Mon Dec 29, 2008 11:19 am    Post subject: Reply with quote
No good on the carb change from this viewpoint also. Not nearly enough cubes for a 4bbl.
Like other posts have said, the early 2.8L motors had lots of problems. You're better holding off holding out for a 350. I've even got a strong runner 350 in the shop for about $350.
