GREG DAVIDSON Member
Posted: Thu Nov 27, 2008 2:07 pm Post subject: |
yea its fast but i bet it cost 10 time as much to build _________________
Posted: Thu Nov 27, 2008 2:08 pm Post subject: |
So...Where does the power for the battery come from? _________________
Posted: Thu Nov 27, 2008 3:01 pm Post subject: |
| They use some crazy batterys. I'm sure they get charged. |
Posted: Thu Nov 27, 2008 5:09 pm Post subject: |
| Twilightoptics wrote: | | They use some crazy batterys. I'm sure they get charged. |
I was just trying to convey the idea that it's not "green" if you have to produce those batteries some where (as well as mine and/or refine the hard metals inside them) as well as whatever type of power plant is used in your area to supply juice. Electric/hybrid cars are FAR from green.
Posted: Thu Nov 27, 2008 6:27 pm Post subject: |
| I totally agree. Just not a great manufacturing process. But you have to admit 11.xx is fast for an electric car. |
Jason_Culbertson Member
1982 Pontiac Trans Am
Posted: Thu Nov 27, 2008 11:41 pm Post subject: |
yea that's true its fast, id take a 3rd gen over it any day _________________ ****______****
___/,__;i__ \
[___ _ ____;.ŻŻŻl
\_(O)______(O)_/
"Smoke tires not drugs"
VW and Audi tuner on Forza 3 |
Posted: Sat Nov 29, 2008 2:05 am Post subject: |
I remember when they were doing all that filming for electric vehicles. That electric drag bike is also the quickest electric bike in the world. Running low low 8's. Just to let you know, that bike is too loud to normally run at PIR. it runs in the mid 90's for it's dB level simply because of the air it displaces as it runs by you. To put that in perspective, Paul's IROC is right at 90 db. there used to be another electric vehicle, I think it was a Geo metro, that ran at PIR. hasn't been back since it hit the wall though. it was chain drive and the chain snapped and locked up the rear wheels around the 330'. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
