3.1L +0.060 V6 with 700r4 for sale
PostPosted: Mon Sep 29, 2008 11:55 am    Post subject: 3.1L +0.060 V6 with 700r4 for sale Reply with quote
K, you all know the deal. This engine will never be used again in any project car of mine so its up for sale. I have about 15k miles on the rebuild, first 5k with dino oil, last 10k on castrol syn. Just had it dyno'd and I know the cam is the problem. It runs strong (151ft.lbs to the wheels) but not enough intake flow to take advantage of the cam. 3 angle valve job, new guides, new springs, retainers. Check my V6 cardomain in my signiture for more details. This would make an AWESOME S10 motor. For the record its an 1989 V6, one piece rear main, 92 cavalier 3.1 crank, 0.060" overbore pistons, stock CR (8.9:1), stock 3.1 rods (factory forged), hi-volume pump. It has made noise only when it's really cold during the winter. It does not have the knock sensor boss for a speed density setup for 91-92 camaro's.
Tranny is a 180k mile 700r4. Corvette 1-2 servo deal, slight shift kit. It works flawlessly and the torque converter is original to the tranny. It has only been off this engine ONCE. I would't sell a tranny that isn't good or questionable cause I've been burnt before and it sucks. It has the camaro tail shaft (obviously), no cracks, oil pan drain plug, and has the speedo gears for a 3.42 rear end.
I will deliver if you cover gas costs. We'll start this at the price below but I'm open for suggestions, trades, barters, and negotiations.
$900
PostPosted: Tue Sep 30, 2008 7:24 am    Post subject: Reply with quote
Going on craigslist.
