Cascade Crew Message Forums
Camaro350Z28 Member
Posted: Sat Jul 03, 2004 10:22 am Post subject: Sound like an ok deal you think? |
As for the specs,
the crank has been ballanced ( stock crank) it has eagle H-beam rods they're
good up to about 600 HP, hypereutectic 11.1 pistons (don't plan on forced
induction with these pistons), LT4 HOT cam, 1.6 Rockers, the heads are stock
LT1 heads with mild porting, the intake has mild porting and has been powder
coated, the exhaust ports on the heads have been port matched to the
manifolds... it will also work with headers. The sensors are there except
for the maf that's the only thing i couldn't grab from my friend... your
fuel pump should be fine, i would just change the fuel filter out. the O2
sensors are in the manifolds themselves so no worry about that... but if
you're going to run em you're going to need rear O2 sensors ( about 1% of
swaps use the rear O2). I have the EGR and all the emmisions BS if you're
going to run all that which not many people do, but I don't know what the
condtions are up there. I don't have any fans, I was going to go last week
to go pick up some from the local junk yard... ummm what else... it is a
stock throttle body but it's brand new it only has 5k miles on it, it's very
very clean... the injecters have been upped to 26lb injecters... The only
thing I can think of that you're going to need for this swap to make it run
is a wiring diagram which is on TGO and a MAF that's about it. You may need
some misc. stuff for it from home depot or whatever for bolts but i doubt
it... I have the fuel lines so no worries about that, the powersteering pump
and resivoir. I also have a complete wiring harness for you out of a 96
Trans am. Anything else just let me know..
this is the motor i am thinking about. I curious to what you guys think, sound like an ok motor? the guy told me it ran a 12.7 and that was without headers or air intake of any kind. hes lookin to get 1900 from me or maybe trade for that new RS i have sitting in my driveway. whatcha think?
Tim |
Posted: Sat Jul 03, 2004 9:20 pm Post subject: |
| well, the LT4 hotcam, in an lt4, makes 425hp. i dont know how ported LT1 heads compare, but i doubt they flow quite as well. so i would guess that is in the 380hp range or so. not to shabby. should propell and RS plenty fast to get you into trouble. |
Camaro350Z28 Member
Posted: Sun Jul 04, 2004 10:11 am Post subject: |
propel a z28... but maybe ill have to upgrade that intake and heads then before i do anything.
Tim |
