Jason_Culbertson Member
1982 Pontiac Trans Am
Posted: Fri Sep 12, 2008 12:35 am Post subject: 350 TPI swap ideas and Q's |
so i want a 383 for my T/A but i was thinking something a little more of a sleeper. so im thinking about a 350 tpi, how much could i get a rebuilt/ good used one for? or how much for the swap all together? thanks _________________ ****______****
___/,__;i__ \
[___ _ ____;.ŻŻŻl
\_(O)______(O)_/
"Smoke tires not drugs"
VW and Audi tuner on Forza 3 |
Posted: Fri Sep 12, 2008 2:58 am Post subject: |
Find me a good cheap LQ series for the IROC and you can have a true L98 with less than 90K on it.
Realisticly though, there's a limit to anything that you can do with TPI. It simply will not make good power at high RPM's. |
cameron7710 Member
Posted: Fri Sep 12, 2008 5:11 am Post subject: |
| aaron_sK wrote: | Find me a good cheap LQ series for the IROC and you can have a true L98 with less than 90K on it.
Realisticly though, there's a limit to anything that you can do with TPI. It simply will not make good power at high RPM's. | i agree a tpi wouldnt be the best choice pus would cost a lot to switch to id say go carburated if not already _________________
Posted: Fri Sep 12, 2008 6:46 am Post subject: |
so i got a 305 w/4bbl i like it but the tpi looks a lot better to me and there are more parts for 350's then 305's _________________ ****______****
___/,__;i__ \
[___ _ ____;.ŻŻŻl
\_(O)______(O)_/
Posted: Fri Sep 12, 2008 6:51 am Post subject: |
What do you mean there are more parts for 350s than 305s?
They take the same parts except for the crank/rods/pistons.... |
Posted: Fri Sep 12, 2008 7:05 am Post subject: |
ur kidding me well i still want one _________________ ****______****
___/,__;i__ \
[___ _ ____;.ŻŻŻl
\_(O)______(O)_/
Posted: Fri Sep 12, 2008 7:55 am Post subject: |
I agree on the upper rpm thing. TPI's just wont spin the rpms. But then how often do you run a motor there?
If your currently carb, it will take alot of cash to make it FI.. ALOT more parts then if you were already FI. |
Posted: Fri Sep 12, 2008 9:38 am Post subject: |
your money is better spent on a better cam, intake, headers and possibly carburator, and maybe steeper gears, rather than try to convert to TPI. _________________
Posted: Fri Sep 12, 2008 10:30 am Post subject: |
| 91RSVert wrote: | | But then how often do you run a motor there? |
Every single day, baby!
Posted: Fri Sep 12, 2008 10:32 am Post subject: |
 _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Fri Sep 12, 2008 11:06 am Post subject: |
| aaron_sK wrote: | | 91RSVert wrote: | | But then how often do you run a motor there? |
Every single day, baby!  |
Guess you drive different then I do. I rarely rev it past 3600rpms. |
Posted: Fri Sep 12, 2008 10:59 pm Post subject: |
| 91RSVert wrote: | | aaron_sK wrote: | | 91RSVert wrote: | | But then how often do you run a motor there? |
That's because you're practically out of your powerband by then  _________________
Posted: Sat Sep 13, 2008 5:25 am Post subject: |
yep, agree. I think my max is at 3800-4000?
Plus with all the hills, idiot drivers, you just dont have roam to spin it up that far. |
Posted: Sat Sep 13, 2008 9:32 am Post subject: |
I spin it that far just to piss off idiot drivers, since I have no real muffler to speak of.  |
Posted: Sat Sep 13, 2008 12:28 pm Post subject: |
| If you want the look of TPI, get it. If you want monster torque without effort, get it. If you wanna go fast, get something else. |
